Home made short shifter
Old Aug 9, 2008 | 01:04 AM
kylerwho's Avatar
spoon fed
I am pretty sure i am the only one to have this on my fit. I got the idea from driving my uncles bmw. I have the skunk2 short shifter adapter and i wanted an even shorter throw. I pulled the shift lever out, cut out about 3 and a half inches, and welded the threaded section onto the shortened lever and PRESTO!! THE ULTIMATE SHORT SHIFT!
<a href="301989099_1026951653_0.jpg - Image - Photobucket - Video and Image Hosting" target="_blank"><img src="http://i514.photobucket.com/albums/t...26951653_0.jpg" border="0" alt="Photobucket"></a>
sorry for the crappy cell phone pics. Shifts with only wrist motion.
Old Aug 9, 2008 | 01:10 AM
koolkevin1107's Avatar
the pix don't work, it says going through maintence. U should put it up with imageshack.us
Old Aug 9, 2008 | 01:14 AM
TitePhit's Avatar
Yeah, I wish I could see them.
Old Aug 9, 2008 | 02:17 AM
kylerwho's Avatar
spoon fed
Image of short shifter - Photobucket - Video and Image Hosting
does that work?
Old Aug 9, 2008 | 02:24 AM
Fa1's Avatar
Fa1
first link in second post works. Looks good, hope your welds hold up.
Old Aug 9, 2008 | 02:30 AM
JDMchris.com's Avatar
I run THIS
haha thats ridiculously low. would remind me of suicide shifting on choppers.
Old Aug 9, 2008 | 02:38 AM
TitePhit's Avatar
nice, looks good man!
Old Aug 9, 2008 | 02:39 AM
kylerwho's Avatar
spoon fed
Im going to try kill me some synchros!!
Old Aug 9, 2008 | 12:15 PM
PwRmAd's Avatar
what material is it steel, s.s or aluminum?
Old Aug 9, 2008 | 12:16 PM
CuTeBoi's Avatar
isn't that NOT a short shifter?
aren't short shifters longer and closer to the steering wheel, but require less motion to shift?
I'm sort of lost on why the shortening of the handle and putting it further away from your available hands.
(reminds me of a video someone made me watch that a girl liked about her nice stick shift.......)
Old Aug 9, 2008 | 12:24 PM
tItAnIuM's Avatar
Do you have the video still?
Cutting the handle does not make it a "short shifter". The short part comes from the length of the throw at the gear box. Not that it is stumpy. Remember, bigger is better for the height, not the length.
Old Aug 9, 2008 | 12:32 PM
CuTeBoi's Avatar
I didn't keep the video... it was sort of interesting what an S2000, and a Porsche can do for a woman..... I don't think the stains will come out of the upholstery
Old Aug 9, 2008 | 12:38 PM
tItAnIuM's Avatar
Damn you. No rep for you then!!!
Old Aug 9, 2008 | 01:29 PM
PwRmAd's Avatar
to answer my self its not aluminum (magnetic) and looks like stainless steel to me.
Old Aug 9, 2008 | 04:06 PM
kylerwho's Avatar
spoon fed
It is a mild steel with a coating on it. Most stainless steels are martinsetic and not magnetic. I used a 308 stainless rod to weld it just in case. plus it wont rust.
Old Aug 9, 2008 | 05:08 PM
PwRmAd's Avatar
wait so i can weld mine with mild steel and then coat or paint it
Old Aug 9, 2008 | 05:43 PM
kylerwho's Avatar
spoon fed
im sure you could. make sure you put a little bevel on both sides and it should hold. depends on the process you use too. I used tig. i went the stainless route to save it from any corrosion.
Old Aug 9, 2008 | 06:09 PM
PwRmAd's Avatar
yea i want to do this but i only have a mig welder thats not set up for stainless. I think ill give it a try. Worst comes to worst i can buy a mugen short shifter
Old Aug 9, 2008 | 06:12 PM
PwRmAd's Avatar
did you remove it from the car before welding. From the diy mugen install it looks like stuff has to be broken to get it out
Old Aug 9, 2008 | 06:15 PM
kylerwho's Avatar
spoon fed
I took it out of the car first. It was difficult but everything came out fine. took about 30 minutes to get it out and about 10 to put it back in.
