The Most Advanced Quadruped Robot on Earth
Old Aug 11, 2008 | 01:36 PM
gofastredfit's Avatar
From: Hampton Roads, V A U.S., Earth, Milkyway Galaxy
Boston Dynamics: The Leader in Lifelike Human Simulation
BigDog is the alpha male of the Boston Dynamics family of robots. It is a quadruped robot that walks, runs, and climbs on rough terrain and carries heavy loads. BigDog is powered by a gasoline engine that drives a hydraulic actuation system. BigDog's legs are articulated like an animal’s, and have compliant elements that absorb shock and recycle energy from one step to the next. BigDog is the size of a large dog or small mule, measuring 1 meter long, 0.7 meters tall and 75 kg weight.
BigDog has an on-board computer that controls locomotion, servos the legs and handles a wide variety of sensors. BigDog’s control system manages the dynamics of its behavior to keep it balanced, steer, navigate, and regulate energetics as conditions vary. Sensors for locomotion include joint position, joint force, ground contact, ground load, a laser gyroscope, and a stereo vision system. Other sensors focus on the internal state of BigDog, monitoring the hydraulic pressure, oil temperature, engine temperature, rpm, battery charge and others.
In separate trials, BigDog runs at 4 mph, climbs slopes up to 35 degrees, walks across rubble, and carries a 340 lb load.
BigDog is being developed by Boston Dynamics with the goal of creating robots that have rough-terrain mobility that can take them anywhere on Earth that people and animals can go. The program is funded by the Defense Advanced Research Project Agency (DARPA).
Old Aug 11, 2008 | 03:35 PM
GD3-Fit's Avatar
I <3 SPOON
how is BigDog more advanced than Asimo??
ASIMO Humanoid Robot - Honda Robotic Technology Tours N America
ASIMO is designed to operate in the real world, where people need to reach for things, pick things up, navigate along floors, sidewalks, and even climb stairs. ASIMO's abilities to run, walk smoothly, climb stairs, communicate, and recognize people's voices and faces will enable ASIMO to easily function in our world and truly assist humans.
BigDog just sounds like a workhorse compared to Asimo
-Ricky
Old Aug 11, 2008 | 05:57 PM
Kyle is raaddd's Avatar
Master FitFaker. CHEA!
yeah asimo ftw
rob i tried to rep you, but it was to no avail
Old Aug 11, 2008 | 08:23 PM
Fa1's Avatar
Fa1
Metal Gear !?!?!?!?!
Occam
Off Topic Discussion
Jan 27, 2011 04:13 PM
azncarbos
General For Sale Section
Mar 18, 2009 05:18 PM
JDMchris.com
22
Sep 21, 2007 07:19 PM
KentuckyFit
Jun 14, 2007 08:46 PM
