1992 CIVIC
Old Sep 25, 2005 | 09:30 PM
OLDGIRLPAPPAS92
Guest
Posts: n/a
1992 CIVIC
NEED HELP SETTING TIMING
Old Sep 26, 2005 | 10:30 AM
TeGGeR®
Guest
Posts: n/a
Re: 1992 CIVIC
"OLDGIRLPAPPAS92" <bgpappas68@aol.com> wrote in
news:418de6d928984dd57f5a651682d2d82b@localhost.ta lkaboutautos.com:
Don't shout. Turn off CAPS LOCK key.
Engine must be full-warm. All acessories off.
1) Jump grey 2-pin connector behind top of passenger kick panel (use paper
clip).
2) Hook up timing light.
3) Loosen the lower two distributor bolts, but don't loosen the top one
yet.
4) Start engine. Check timing. If adjustment needed,
5) Loosen top dist bolt. Turn distributor so mark on timing belt cover is
in the MIDDLE of the group of three on the crank pulley.
6) Tighten top distributor bolt to lock timing in place.
7) Turn off engine. Remove paper clip and timing light.
8) Do up other two distributor bolts.
TeGGeR®
www.tegger.com/hondafaq/
Subhabrata Bhattacharyya
Oct 12, 2005 08:30 PM
ksrogers
Jul 10, 2005 12:33 PM
Rocky
Jun 6, 2005 03:11 PM
punkyw
May 15, 2005 07:30 PM
Blackhill
May 4, 2005 11:16 AM
