93 Honda Civic AC Only Works Occasionally HELP! ???? ....
Old Sep 26, 2005 | 09:32 PM
Briantanksley@aol.com
Guest
Posts: n/a
Hello everyone. I recently bought a very nice 1993 Civic DX 4 door. The
air conditioning only works when you first start the car and can last
up to 10 minutes or so before it stops getting cold. If left on, it
sometimes kicks back on. Any idea's on this? I recently had it
converted to R134a coolant and it still does the same thing. When it's
working, it's ice cold. Any help is greatly appreciated. Thanks in
advance.
Brian
briantanksley@aol.com
Old Sep 27, 2005 | 12:30 AM
duckbill
Guest
Posts: n/a
Re: 93 Honda Civic AC Only Works Occasionally HELP! ???? ....
Your AC might be freezing up from moisture internally. Have you replaced
your receiver dryer and was your system evacuated properly to remove all
moisture when you had your system converted? It might be kicking back in
after the ice melts and then running for a short time? Good Luck.
Old Sep 27, 2005 | 12:30 PM
Guest
Posts: n/a
I have not replaced my receiver dryer. Unfortunately, I'm not even sure
what that is. I had the system evacuated and converted professionally.
They told me that to completely have it converted that I would need a
new compressor. Is this true? Thanks for the reply.
Brian Tanksley
Old Sep 27, 2005 | 10:31 PM
chip
Guest
Posts: n/a
>Brian Tanksley
no need for a new compressor. There's no way of telling what's wrong
without low and high pressure readings. Get a set of guages on that
thing.
Chip
psamtik
Jun 26, 2018 11:39 AM
phybere
May 29, 2018 11:46 PM
elmo
Aug 12, 2005 11:34 PM
mvarcola
Jun 22, 2005 01:43 PM
Nobody
Jun 13, 2005 03:26 PM
