87 Acura Integra driveshaft nut size? And some thoughts on the torqueconverter
Old Sep 27, 2005 | 08:39 AM
Mauricio Tavares
Guest
Posts: n/a
Does anyone know the size of the nut that holds the driveshaft to the
wheel in the 87 (ok, 86-89) Acura Integra? I am going to take the tranny
out and found out my 30mm socket (used in VWs) is way too tiny...
On another note, have any of you ever experiencing the starter gear (as
in flexplate scaled down to a ring welded to the torque converter at 6
points) breaking the above-mentioned welds so it now wobbles and cannot
get to the starter? If not, make a point not to. I am not even being
able to find a replacement... :P
Mauricio raub-kudria-com
(if you need to email me, use this address =)
Old Sep 27, 2005 | 09:35 AM
jim beam
Guest
Posts: n/a
Re: 87 Acura Integra driveshaft nut size? And some thoughts on thetorque converter
> the wheel in the 87 (ok, 86-89) Acura Integra? I am going to take the
> tranny out and found out my 30mm socket (used in VWs) is way too tiny...
think it's the same as the later models - 32mm.
> (as in flexplate scaled down to a ring welded to the torque converter at
> 6 points) breaking the above-mentioned welds so it now wobbles and
> cannot get to the starter? If not, make a point not to. I am not even
> being able to find a replacement... :P
it happens. get one from a junk yard or buy new. this vehicle is still
supported. acuraparts247.com. not cheap!
Mauricio Tavares
Guest
Posts: n/a
Thanks! Sometime this afternoon I will be going to the parts shop and
getting an impact socket of that size. I draing the tranny and
disconnected the shifter and speedo cable and the cooler hoses
yesterday. Hopefully I will have the tranny out of the car today. :)
>> gear (as in flexplate scaled down to a ring welded to the torque
>> converter at 6 points) breaking the above-mentioned welds so it now
>> wobbles and cannot get to the starter? If not, make a point not to. I
>> am not even being able to find a replacement... :P
Most definitively not cheap. Ouch! It is about as much as the car's
worth. I guess it is time for the used route... :(
MyFitment
Aug 2, 2020 03:29 PM
apprentice
Nov 27, 2011 03:41 PM
kodo
Jan 10, 2008 03:29 PM
trs80
Jun 13, 2005 03:26 PM
mmdir2002@yahoo.co.uk
May 4, 2005 11:16 AM
