The dipstick tube is stuck, how did you pull it out?
Old Oct 9, 2016 | 04:51 PM
MyFitment's Avatar
Unhappy The dipstick tube is stuck, how did you pull it out?
Im trying to replace the POS starter in my 08 fit but the dipstick tube wont come out of the block. I removed the 10mm bolt and bracket that holds it in place. I can rotate it, twist it, but it wont pull up and out.
Is there a trick to getting it out??
Replacing this starter is a bitch! I wish it was as easy as the b series starter.
Old Oct 25, 2016 | 10:36 PM
MyFitment's Avatar
Bump. please help
Old Oct 26, 2016 | 07:15 AM
Hondu's Avatar
Originally Posted by MyFitment
Bump. please help
Have it towed to a dealer to do the work. Never heard of removing a dipstick tube to replace a starter.
Old Nov 2, 2016 | 02:58 PM
MyFitment's Avatar
anyone else? someone please answer how did you get the dipstick removed?? you cant access the starter because its in the way. for the people who replaced their starter in their 07-08 fit how did you get the dipstick tube out?
Old Nov 2, 2016 | 05:38 PM
dwtaylorpdx's Avatar
Generic answer, dipsticks, They are usually driven in with a hard mallet, In my experience they are removable, but you have a chance of bending them. They often have a bit of a flare on the bottom end that tends to kind of lock them in, I put a bolt in the top end so I can grab it with some vice grips and drive it out by tapping on the vice grips, but I haven't done the honda one..
Old Nov 9, 2016 | 08:12 AM
MyFitment's Avatar
Please help!! Again for the people who actually replaced their starter in their 07-08 fit, how the **** did you get this dipstick tube out????
Old Nov 9, 2016 | 08:08 PM
I've changed my starter and it wasn't in the way... I was assuming yours was just a different build date or location so its a different tube. sorry I somehow didn't add that..
Old Nov 9, 2016 | 11:53 PM
ezone's Avatar
If you have removed the one bolt and gotten the dipstick tube to twist freely in its hole, it should pull straight out.
It may require some effort to pull out. Twist it back and forth as you pull?
There is a rubber O ring that seals the tube into the hole.
Old Nov 10, 2016 | 08:11 AM
MyFitment's Avatar
I did that. Itll twist around in its hole, but it wont pull out. Its seriously like stuck in there. I tried vice grips even, it just wont come out...
Old Nov 17, 2016 | 12:39 PM
MyFitment's Avatar
BUMP Anyone have any other suggestions? This is seriously pissing me the &&&& off now.
Old Dec 5, 2016 | 08:09 AM
MyFitment's Avatar
bump. still trying to get the dipstick tube out. my starter is also grinding every morning, im worried that it wont start one day and I wont make it to work.
Old Dec 8, 2016 | 06:05 PM
bex's Avatar
bex
i think your out of the weekend warrior department and over to the pro repair guys. Take it to a dealer and let them change it out. If you botch the dipstick removal and and left leaking oil, what then?
Old Dec 27, 2016 | 12:11 AM
KingMel's Avatar
I had to remove the dipstick tube on my 2009 Honda Fit Sport to replace the starter. It was a bit of a pain. I tried rotating an pulling by hand without success. I did not want to damage the tube, so I tried a pair of large needle nose pliers on the bracket welded to the tube. I wiggled and twisted and it popped free. Try to keep the pull straight out to avoid binding. When reinstalling the dipstick tube, lube the O-ring with a little engine oil or silicone grease (my preference). It will slide back in so easy that you will wonder why it was so difficult to remove.
Old Aug 19, 2018 | 12:55 PM
Hudson_Fit's Avatar
This thread is sort of dead, but I'll comment for anyone who finds it from Google when doing a starter repair. The dipstick tube is in the way of the starter, and I had to remove it to pull the starter on my wife's 2008 Fit Sport. That was one of the worst parts of what was already a difficult job. After 10 northeast winters the tube was in there pretty good.
I already had the car up on jack stands, and had removed the plastic "splash guard" that covered the bottom of the car. I also removed the oil filter, which gave me significantly more room to work with. That step might not be absolutely necessary, but I think it's worth it.
To take the dipstick out I first removed the bolt (10mm?) that was on the small bracket on center of the tube, but the tube wouldn't budge. What finally worked was first generously spraying the base of the tube (where it meets the engine block) with some penetrating oil (PB blaster) and then letting it sit for 30 minutes.
I then took a 10 inch piece of steel rebar and a hammer, and laying underneath the vehicle I used the rebar and hammer to tap the bottom side of the bracket from underneath. After I gave a few good taps on the bracket I wiggled the base of the tube from side to side a little bit. I continued spraying, tapping, and wiggling the tube until it came free.
To reinstall I coated the base of the tube and the o-ring with grease, and pressed it in with my hand while standing above the engine. I also found a length of scrap wood (around 1x1/2x12 inches), and with the oil dipstick removed, placed the wood on the top of the tube and lightly tapped the wood with my hammer. It went in much easier than it came out. Then you just need to reinstall the bolt. I did not replace the o-ring at the bottom of the tube, and so far it doesn't appear to leak. But I'll be checking on it, and if I was going to do this job again I might replace it just to be safe.
Old Aug 2, 2020 | 03:29 PM
fit09's Avatar
Ran across this old post about removing the dip stick, thanks for the tip about section of rebar and hammer to tap on the tube bracket. Saw a YouTube and someone used a long chisel and hammer to do this as well.
Sebas Td
Mar 2, 2019 11:53 AM
joe cool
Jul 23, 2018 10:44 AM
SevereService
Jun 25, 2014 08:02 PM
DCTepper
Nov 22, 2013 07:41 AM
mmdir2002@yahoo.co.uk
May 4, 2005 11:16 AM
