Leak Around the Rear Shock. Inside Car
Old Aug 21, 2008 | 07:18 PM
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
FL has been having lots of rain lately. Even before Ive never had this problem. Its a VERY odd leak IMO.
Some of you know Im currently on Skunk2 Pro-C coilovers.
Where the rear shock comes through the rear of the car. Theres 2 rubbers. One on the bottom and one on the top, then a sleeve in the center.
That little "cup" that the top rubber sits in it; is it suppose to be welded?
Well, when I go over bumps water is forced through the body and the bottom of this cup. Bubbles and water ends up dripping down the body after a few bumps. The sound is annoying.
Im not worried about the leak so much. Im mainly worried about the cup breaking and my shocks shooting into my rear hatch.
That bubble at the base of the cup is water.
Anyone else find this odd?
Old Aug 21, 2008 | 07:21 PM
solbrothers's Avatar
werd. imma go check mah yazz. i have a funny sound coming from the rear shock area. thought it was the springs.
Old Aug 21, 2008 | 07:41 PM
carramrod's Avatar
if its leaking water then yes i would weld it or something where the water is comming in from. Or call Skunk2 and let them know and see what they can do for ya
Old Aug 21, 2008 | 07:42 PM
the part that is leaking is the STOCK part. not skunk2
Old Aug 21, 2008 | 08:07 PM
carramrod's Avatar
maybe the SKUNK2 part caused the STOCK part to leak in the first place? ever think of that? :0
Old Aug 21, 2008 | 08:12 PM
BLASPHEMY!!!!!!!!!!!!!!!!!!!
:P
Old Aug 21, 2008 | 08:24 PM
carramrod's Avatar
Old Aug 21, 2008 | 08:25 PM
mahout's Avatar
I'd say you have cracked the cup and thats how water is getting in. Water is 'pumped in' during rain when the shock piston rod 'hits' the bottom of the cup seat in the joint. That means its constantly subjected to repeated hitting. Unfortunately, that will lead to a more serious problem when the cup breaks away from the fender. You will lose shock control and potentially conrol of the Fit. FIX IT NOW. Both left and right sides. Notice I didn't say if but when. Guaranteed. Even before you drive again !
Needless to say, welding the cup back is imperative. Unfortunately its not a good place to be welded in as the two surfaces are shrouded by the edges, but it can be done. At the same time I would have both sides cups attachment to the fender reinforced with ribs or 'tiebars' welded in place.
Its just one of the hazards of lowering a suspension.
good luck.
Old Aug 21, 2008 | 10:34 PM
manxman's Avatar
good luck.
Ray, I hope that you don't listen to mahout, so that I can laugh about the sad results. Good advice, mahout. Letting your lowered suspension hammer your car apart is guaranteed bad news. Good news for people who don't wish you well.
Old Aug 22, 2008 | 01:40 AM
doctordoom's Avatar
Supervillain
eek, reading mahout's explanation sends chills down my spine. best of luck with everything ray.
Old Aug 22, 2008 | 08:54 AM
LOL @ the misinformation
Old Aug 22, 2008 | 09:13 AM
CuTeBoi's Avatar
Good luck...
Old Aug 22, 2008 | 06:03 PM
RickyGoshDarn's Avatar
Is it coming out of the bottom of the cup where it's welded? or the part where the gasket is? I kinda have this problem on my used T1R's and I have been driving on them for 20k. I believe it's just the water getting through the gasket.
Old Aug 22, 2008 | 06:55 PM
Posts in the NUUDE
Its coming from the bottom of the cup. Theres no weld around the cup itself. Its just smooth.... Id guess its welded from the bottom?
I mean, its apparent the cup is detaching from the car.
I do plan on getting it welded. I should have did it yesterday. The shop next door to my job is a welding shop. They would do it for free.
Old Aug 22, 2008 | 07:36 PM
Posts in the NUUDE
Driverside.
Passenger.
It doesnt even really seem like this piece can come detached from the car?
Unless most of the area comes off from around it.
I pried on it with a pry bar just to see if it moved. It didnt.
Its just TINY little holes, unfinished areas that the water is passing in from.
Old Aug 22, 2008 | 09:32 PM
Fa1's Avatar
Fa1
Did you remove a covering for the shock or it comes like that?
Old Aug 23, 2008 | 12:30 AM
Posts in the NUUDE
I slid the cover down. Its there.
Old Aug 23, 2008 | 11:07 AM
MarkyMark's Avatar
Maybe you could take the shock out, mask off the hole to the inside of the car, and spray that area with rubberized undercoating and reinstall the shock?
Old Dec 15, 2008 | 09:46 PM
cowflex's Avatar
err is anyone else having this problem? I'm on skunk2 pro-c as well and I just noticed today that I have a ring of water around that area too.
Old Dec 15, 2008 | 10:20 PM
Posts in the NUUDE
I just lived with it. If enough water gets around the top of the shock bump stop itll force the water inside the car.
The sound was what bothered me. Once the rain is gone the sound is gone.
Havent had any problems besides the small leak.
