seat lowering
Old Aug 22, 2008 | 02:51 PM
MemphisFit's Avatar
seat lowering
is there any way to drop my seat down about an inch to inch 1/2???
i feel like im sitting on top of the steering wheel
Old Aug 22, 2008 | 06:22 PM
MemphisFit's Avatar
NOBODY????????????????
Old Aug 22, 2008 | 06:29 PM
Tofuman's Avatar
you'll probably have to get an aftermarket seat and seat rails. i don't believe any seat rails fit the OEM seats.
Old Aug 22, 2008 | 06:48 PM
ClaytonS15's Avatar
I wish I knew, because I would love to raise my seat about 1/2". My right leg cramps up on long drives...
Old Aug 22, 2008 | 06:58 PM
Kyle is raaddd's Avatar
Master FitFaker. CHEA!
yeah aftermarket seats/rails should do the trick
Old Aug 22, 2008 | 07:07 PM
Tofuman's Avatar
j/k.
Old Aug 22, 2008 | 07:13 PM
ClaytonS15's Avatar
Originally Posted by Tofuman
j/k.
That's one solution! Lol!
Old Aug 22, 2008 | 07:25 PM
Tofuman's Avatar
in all seriousness, you might look into finding a seat cousion that extends past the seat bottom slightly to support your leg and may raise your seating position a little. at least until a better solution is discovered. it will be better for your legs.
Old Aug 22, 2008 | 09:33 PM
mahout's Avatar
Only a machine shop fabrication will shorten or lengthen the legs. Probably with inserts in cutoff legs. Not real easy to do.
As mentioned you can search after market seats for easier solution.
Old Aug 23, 2008 | 12:05 AM
Tofuman's Avatar
Originally Posted by mahout
Only a machine shop fabrication will shorten the legs. Probably with inserts in cutoff legs. Not real easy to do.
good idea for an alternative. but i'd have a hard time trusting a machine/welding shop to customize something as important as seat brackets/rails. in the event of an accident, i want some seat rails i can trust.
Old Aug 23, 2008 | 02:30 AM
well, the only upside would be if you got in a wreck and they broke, you could sue!!!
can someone say FI?!?!
haha but really that would suck
Old Aug 23, 2008 | 02:34 AM
hotpot's Avatar
I have a problem with the seats too, i went on a 50 miles on the highway and my butt/back/lower leg is still hurting. maybe moving the seat all the way back?
Old Aug 23, 2008 | 02:44 AM
ProMed's Avatar
Several guys, who do not have the height adjustable seats, on the 4Runner boards I frequent have put washers under the bolts that hold the rails to the floor. Most guys were just putting them under the rear bolts to tilt the seat forward, but some were putting them under both the front & rear. Not sure though how the Fit rails are attached?
crozewski
Oct 21, 2015 03:41 AM
JaStonE
Jan 3, 2011 02:28 PM
DGArch
Oct 19, 2010 09:09 AM
rac1201
Dec 22, 2007 04:02 PM
pastafarian
Nov 24, 2007 10:44 AM
