Hid's And The 2009 Fit
Old Aug 27, 2008 | 11:41 AM
vtecfit1's Avatar
Question Hid's And The 2009 Fit
JUST WONDERING , I HAVE LOOKED AT A NEW 2009 FIT IN PERSON AND IT HAS DAYTIME RUNNING LIGHTS(I HATE THEM ON ANY CAR) BUT DOES ANYONE KNOW, IF IT'S POSSIBLE TO INSTALL A HI/LO HID SET UP LIKE ON MY 2007 SPORT, WITHOUT THROWING ANY CODES ?
Old Aug 27, 2008 | 12:07 PM
Smallville's Avatar
I was wondering about this as well. Just for fun I may try and hook a set up I have to see what happens.
Old Aug 27, 2008 | 12:16 PM
non use of DRL's shouldn't trigger any DTC's especially for the USDM fits.
on the 06 civic i had, it was just a yank on the fuse.
Old Aug 27, 2008 | 07:16 PM
ProMed's Avatar
Has it been confirmed that the DRLs are the headlights? My 4Runner uses the running lights, not the headlights, for the DRLs.
Old Aug 28, 2008 | 03:04 AM
mole177's Avatar
^ actually... it's the turn signal lights that are used as DRL.
Old Aug 28, 2008 | 11:58 AM
vtecfit1's Avatar
Hid's Part 2
I Have Pulled Out The Bulb For The Fit 09 And Here Is What I've Found
Uses A Hb2 Bulb (two Filiment Bulb) Drl Is Hi-beam (rear Filiment) With Low Voltage
Lo-beam Is Front Filiment With Regular Voltage
Hi-beam Is Rear Filiment With High Voltage
On Some Honda's The Drl Has A Designated Bulb But The 09 Fit Just Uses The Regular Headlight Bulb And Just Limits The Voltage Going To It (lame)
Old Aug 29, 2008 | 01:23 AM
niko3257's Avatar
FitFreak GE8 DIY Guy
now if someone can figure how to disable it.
then post a DIY for all of us
Old Aug 29, 2008 | 02:40 AM
YA2_user_GD3's Avatar
DRL are ***....
Old Aug 29, 2008 | 07:25 AM
kifu's Avatar
Why does everyone hate day time running lights? I just don't get it.
Old Aug 29, 2008 | 09:58 AM
niko3257's Avatar
^^^they just make the car look like crap
Old Aug 29, 2008 | 10:06 AM
Arisenfury's Avatar
If it was anything like my 8th gen Civic who used the high beams for DRLs all you have to do is pull fuse #37 and voila. Just check the back of the fuse box to find which fuse goes to the DRL module.
Old Sep 5, 2008 | 07:24 PM
txmatt's Avatar
Does the 09's have flash-to-pass lights, where you pull the stalk a bit to flash the brights?
If so, will folks be disabling that for bixenon HID kit installs? Many factory HID vehicles either retain halogen bulbs for the brights or don't offer flash-to-pass because those short strikes are really hard on the capsules.
Old Sep 5, 2008 | 08:19 PM
niko3257's Avatar
if someone can pull fuse # 15
we will know for sure if it disables drl.
Old Sep 13, 2008 | 07:52 PM
niko3257's Avatar
well i pulled fuse #15 today.
and it works.
no more DRL
Old Sep 13, 2008 | 07:56 PM
JDM_DOHC_SiR's Avatar
and it works.
no more DRL
Old Sep 13, 2008 | 08:48 PM
matt0807's Avatar
Gave it a shot also - definitely works!
Old Sep 13, 2008 | 11:02 PM
Fat Ping Cat's Avatar
good, i hate DRLs they are so annoying! they cause glare on the road during the day
huge pet peeve of mine! hate them with a passion!
Old Oct 11, 2008 | 06:16 PM
strmslvrfit's Avatar
umm dont wanna stupid here, but when i look at the fuses under the dash there are many different #15 fuses, which one do i pull???
Old Oct 11, 2008 | 06:39 PM
NVM, i got it, its location 15 not fuse number 15 haha
Old Oct 12, 2008 | 03:23 AM
FiveFreshFish's Avatar
I don't see how a pair of 60/55 W bulbs can cause glare during the day when the sun pumps out 3.9 x 10^26 W.
If anything, normal low beam headlights will produce more glare at night.
