91 honda accord has a few problems...
Old Oct 7, 2005 | 02:30 PM
kris82
Guest
Posts: n/a
first off, the S light flashes all the time. The check engine light comes
on after driving it for a little while and lastly... when you turn the car
on it seems to putter (or at least thats what it sounds like) it takes off
fine, but you can feel it "putter" when driving and when stopped at a
light... any ideas?????
Old Oct 7, 2005 | 03:30 PM
TeGGeR®
Guest
Posts: n/a
Re: 91 honda accord has a few problems...
"kris82" <kristalnewsom@nospam.hotmail.com> wrote in
news:225fdc1026ac90936ec4316ee4a21e62@localhost.ta lkaboutautos.com:
Count the blinks. The sequence is separated by a long pause. If there
appears to be just a steady constant blink, it's code 1.
A long blink is worth 10, a short blink is worth 1, so the sequence
long-short <repeat> = code eleven.
short-short-short <repeat> = code three.
> comes on after driving it for a little while
Pull the carpet back in the passenger footwell. There is a small LED set
into the yellow framework you see there. Turn the ignition on (but not
START!), and count the blinks.
Blink sequence is as above. There may be more than one code stored, so
watch carefully.
> turn the car on it seems to putter (or at least thats what it sounds
> like) it takes off fine, but you can feel it "putter" when driving and
> when stopped at a light... any ideas?????
Need those codes first.
TeGGeR®
www.tegger.com/hondafaq/
High Tech Misfit
Guest
Posts: n/a
Does a '91 Accord actually have a LED there? My '93 Accord, which is the
same generation, does not have it and must have its codes retrieved from the
check engine light with the service check connector shorted.
Old Oct 7, 2005 | 06:35 PM
Frank Boettcher
Guest
Posts: n/a
On Fri, 7 Oct 2005 15:14:21 -0400, High Tech Misfit <me@privacy.net>
My 90 has an LED.
Old Oct 7, 2005 | 09:30 PM
TeGGeR®
Guest
Posts: n/a
High Tech Misfit <me@privacy.net> wrote in
news:1pm6eyfevv47x$.dlg@hightech.misfit:
>> set into the yellow framework you see there. Turn the ignition on
>> (but not START!), and count the blinks.
According to my Helm manual, yes.
TeGGeR®
Old Oct 7, 2005 | 10:30 PM
High Tech Misfit
Guest
Posts: n/a
And Frank B. said his '90 has it. I guess Honda removed it for '92 or '93.
I know it's not the best source, but my Chilton book only mentions the
service connector method for retrieving codes on the '90-'95.
Old Oct 8, 2005 | 11:35 AM
Frank Boettcher
Guest
Posts: n/a
On Fri, 7 Oct 2005 21:41:32 -0400, High Tech Misfit <me@privacy.net>
I bought a Honda service manual when my 90 went off warranty. Ugh,
very expensive compared to Haynes, Helms, Chilton, etc. However, best
manual I've ever used with regard to chronological trouble shooting.
I have a Haynes for my 97, however, I always go to the 90 manual first
to see if it applies.
Have you actually looked? Book may be wrong.
Frank
Old Oct 8, 2005 | 12:30 PM
High Tech Misfit
Guest
Posts: n/a
Yeah, I looked a few years ago, and there was no LED.
I don't use the Chilton book religiously. In fact, it was a birthday
present. :-)
Elle
Guest
Posts: n/a
'93.
www.autozone.com 's free repair guide for the 1991 Accord states:
"On 1990-95 Accord (except V-6) and 1992-95 Prelude, the codes are read from
the check engine light after the two-wire service connector has been
jumpered. On Accords, the service connector is under the dash on the
passenger side."
(The autozone site tends to be a replication of Chilton's, though. Still, I
haven't found any notable errors in Chilton's for my 1991 Civic. The
autozone site says 91 Civics have an LED display, and my 91 Civic does.)
PhilRai
Dec 6, 2016 07:12 PM
lmart
Aug 26, 2005 06:01 AM
Kevin McMurtrie
May 15, 2005 07:30 PM
Al Davis
sam
May 4, 2005 11:16 AM
