CRV Auto Shift Lever Question...
Old Oct 13, 2005 | 05:34 PM
John Albert
Guest
Posts: n/a
Hello all -
I'm considering the Honda CRV (either new or late-model used), but have a
question about its oddly-mounted shift lever (I will be shopping for an
automatic transmission).
Does it operate like a standard steering-column mounted shifter (which you
generally have to "depress", move to the next position, then "release" to lock
it in place...
-or-
Does it work like most floor-mounted auto shift levers, which can be freely
moved between the "Drive" and "Neutral" positions?
In other words, if you're driving along, coming to a stop, and you want to go
from "Drive" to "Neutral", can you just nudge it into neutral (and back to
drive) with a simple "push", rather than a "depress/move/lock" movement?
Believe it or not, that's a "car breaker" for me. If it doesn't work like a
floor-mounted lever, I'm not interested in the vehicle, and will shop for
something else that _does_ have a standard floor-mount auto shifter.
Thanks,
- John
Old Oct 13, 2005 | 06:30 PM
Nightdude
Guest
Posts: n/a
Re: CRV Auto Shift Lever Question...
It works a bit different. You don't press any buttons to move it, just press
the brake pedal and then shift. It moves freely between neutral and drive.
You have to nudge it a little bit to move it from Park.
"John Albert" <j.albert@snet.net> wrote in message
news:434ECA47.D76CCB83@snet.net...
> Hello all -
> lock
> it in place...
> -or-
> freely
> go
> a
> Thanks,
> - John
TinyCarEnthusiast
Dec 26, 2016 09:58 PM
fritz269
Aug 11, 2016 08:14 AM
ArmyFit
Aug 6, 2009 11:47 PM
07fitsport
May 6, 2008 02:21 PM
Luichenwai
May 29, 2007 02:16 PM
