Smell of fuel
Old Oct 14, 2005 | 12:31 AM
R. P.
Guest
Posts: n/a
Smell of fuel
Lately I noticed that after each fillup there is the smell of gasoline
in the passenger compartment for a while. What could cause that? I have
a '94 Accord LX.
Rudy
Old Oct 14, 2005 | 03:52 AM
Matt Ion
Guest
Posts: n/a
Re: Smell of fuel
> a '94 Accord LX.
Check the gas cap: they're designed to vent fumes if the pressure gets
too high, but if the spring goes or the vent sticks open, it will leak
fumes all the time, especially if the weather is hot.
Had the same problem with my '87. New gas cap for about $7 was a simple
fix.
avast! Antivirus: Outbound message clean.
Virus Database (VPS): 0541-2, 10/13/2005
Tested on: 10/14/2005 12:23:06 AM
avast! - copyright (c) 1988-2005 ALWIL Software.
http://www.avast.com
Old Oct 15, 2005 | 12:30 AM
R. P.
Guest
Posts: n/a
Re: Smell of fuel
> simple fix.
But the gas cap is outside of the passenger compartment, so how would
the fume get inside with closed windows?
Rudy
Old Oct 15, 2005 | 03:31 AM
Matt Ion
Guest
Posts: n/a
Re: Smell of fuel
>> simple fix.
I dunno, but it sure did...
Virus Database (VPS): 0541-3, 10/14/2005
Tested on: 10/14/2005 11:54:08 PM
Old May 3, 2006 | 09:23 AM
Talon's Avatar
ok..
These are the reason i've had fumes inside before..
Pinhole in the pipe leading out of the tank, fuelline had a small cut in it.. if it's disapearing after a bit I'd say either the venting as others have said or the pinhole.. had that issue with a toyota cut the fuelline due to roads up here and the line from the tank forward got squished. and slit it.. that was on the 82 honda..
Sugarphreak
Jun 7, 2009 04:44 AM
fitjunkie
May 31, 2006 01:40 PM
Erick Larin
Oct 1, 2005 05:31 PM
TeGGeR®
May 4, 2005 04:44 PM
the Warners
May 4, 2005 11:16 AM
