View Poll Results: Should I change my brake pads or should I have the dealer do them?
Do it yourself.
113
74.83%
Bring it to the dealer.
38
25.17%
Voters: 151. You may not vote on this poll
Brake Pad Change
Old Sep 15, 2008 | 07:52 AM
dbcmaster's Avatar
Brake Pad Change
Hey,
I used to do all my own brake pad changes. For the Fit, do you think I should get them done at the dealer or should I do them at home?
Old Sep 15, 2008 | 12:08 PM
rreyes99's Avatar
This is a good question. I would change my own brake pads to save on labor cost as long as I have the right tools. I would invest in quality brake pads that would last longer and give me better performance so i wont have to do it often.
Old Sep 15, 2008 | 12:44 PM
drzenitram's Avatar
if you know how to check your rotors and bleed fluid, do it yourself!
Old Sep 15, 2008 | 12:54 PM
The BOM's Avatar
DIY!
And you don't have to bleed them...
Use a C clamp or giant slip-joint pliers to compress the pistons.
MAKE SURE THAT THE BRAKE FLUID RESERVOIR IS NOT FULL!
It should be low anyways if your pads are low.
Last thing you want is to push BF all over your engine bay
I would go ahead and change the rotors while your at it. Most people believe in turning rotors, i DO NOT. Manufacturers already make the new rotors to thin tolerances, so turning the rotor for another 30k mi usage is unsafe.
Old Sep 15, 2008 | 01:30 PM
dbcmaster's Avatar
Originally Posted by The BOM
DIY!
I use the C Clamp method as well. I only have 12,000 miles on the car. But, I'm starting to wonder how the pads are doing.
Old Sep 15, 2008 | 04:41 PM
jazn's Avatar
u dont have to bleed lines to change pads. Changing pads in pretty much any car is ez breezy. hour max project.
Old Sep 15, 2008 | 04:44 PM
jazn's Avatar
DIY!
yea i also dont beleive in turning rotors, BULL SHIT. a new set is cheap enough. especially if you have some hookups
Old Sep 15, 2008 | 07:42 PM
The BOM's Avatar
Wink
put some light on the subject
Visiual inspection is a good indicator on brake pads.
As for rotors, check for streaks, discoloration, dark spots (hot spots), and run your finger on the very edge of the rotor to check for a lip.
Old Sep 16, 2008 | 04:11 AM
enjoito's Avatar
what happend to taking it to a shop option.
hmm well i know how to change my breaks but i tend not to do it. i just take it to my friends shop. when i change my breaks ceramic pads and ss lines ftw
Old Sep 16, 2008 | 06:47 AM
feddup's Avatar
wuss
I know I could do it myself but Honda's gonna handle it this time. I want my Honda documentation PERFECT as a possible sales/warranty issue.
Old Sep 16, 2008 | 08:28 AM
jezzy's jazz's Avatar
i got myself a set of dixcel pads, but dont no if i shud give them to honda to fit while im gettin the service.. i want to see wat conditions the old pads r in.. personally i think the brakes r crap...
Old Sep 16, 2008 | 03:08 PM
GD3_Wagoon's Avatar
i agree about the factory brakes being crap. with a Fit load of people, the brake fade is scary-dangerous! even when engine braking, it's like the car refuses to stop
i'll be changing up my pads soon too
Old Sep 16, 2008 | 05:49 PM
dbcmaster's Avatar
Any recommendations on good pads to replace to the OEM ones?
Old Sep 19, 2008 | 11:33 PM
Fat Ping Cat's Avatar
bump^
Old Sep 21, 2008 | 07:08 PM
Rayzel's Avatar
I will take it to the dealer. Hek I have the money plus I don't want to waste my time doing it. I will leave it to the pro...
Old Oct 2, 2008 | 01:17 PM
kb8thekid's Avatar
i think this fit was the easiest brake pad change i ever did, it literally took me about 20 minutes to do(something the dealer would take up to an hour and charge you about 160+) i have worked on hondas all my life(DA's mostly) and was hoping that the routine would be the same, i was super glad that it was and it was so easy i was kind of scared that i did something wrong(even though i know i didn't) since i didn thave my jack with me, the hardest part was jacking the car up with the jack that comes with the fit. other than that, piece of cake. if anyone in the Orange/Anaheim/Santa ana area needs help, i would more than happy to help....trust me it's easy.
Old Oct 13, 2008 | 10:57 PM
FitFlowjoe's Avatar
Yea changing pads is really easy.
And if you want something with more bite buy a set of Hawk pads or EBC's for a base Acura RSX.. they line right up no problem. Dont believe me go to a Honda dealer or any auto parts store and compare them side by side ... same sheet!!
I'm using Hawk HPS... and I like them, with slotted rotors from power slot... good combo
Old Oct 13, 2008 | 10:59 PM
JDMxGE8's Avatar
DIY for sure. Dealer FTL.
Old Oct 14, 2008 | 11:33 AM
GD3_Wagoon's Avatar
Hawk HPS pads FTW! if you don't mind me asking, how much did they cost you? everywhere i've seen sells them for $70-$85 for the two front pads.
Old Oct 14, 2008 | 06:25 PM
dbcmaster's Avatar
Where did you buy the pads and rotors?
2006 RSX?
