Securing Rear License Plate
Old Sep 17, 2008 | 01:38 PM
davis61381's Avatar
Any one have a simple question. I tried to do some searching but I'm not seeing anything.
Is there an easy way to secure the rear license plate with all 4 screws? My GF's only uses the top 2 screws and it rattles and doesn't sit flat, which drives me crazy. I don't want to drill anything and She has a license plate surround that she wants to use.
Any Ideas?
Old Sep 17, 2008 | 02:14 PM
manxman's Avatar
Any Ideas?
The Fitfreak license frames that are sold on this site also rattle on the rear hatch when the hatch is closed, opened, or the cars go over rough pavement. There are only two bolts used for the rear anyway. So I drilled a hole at each lower corner, and used 1/8" Pop Rivets to hold plate and frame together. This was 1 1/2 years ago- no rattles at all since then. Rivets are invisible unless you already know that they are there.
Old Sep 17, 2008 | 02:27 PM
1coolride's Avatar
i would say maybe some double sided tape. its pretty strong but it might fall off someday tho
Old Sep 17, 2008 | 02:58 PM
Super Mario's Avatar
Keep the two holes, but lift up the plate from the bottom and slide some foam up there so that it'll be nice and tight. If anything rattles it's the license plate frame.
Old Sep 17, 2008 | 03:08 PM
JamesBizzle's Avatar
works for me and I've have my car for 2 years.
I taped the frame (border) to my plate, and the plate to the hatch.
Old Sep 17, 2008 | 03:29 PM
japspeed's Avatar
i had the same problem, it drove me crazy, i have the oem fit frame from honda, what i did was cut little strips of industrial strength velcro from home depot, and put it in between the plate and the frame, just a few strips as narrow as the frame and a couple inches long did the trick. it has been there for 6 months now with no rattles, and the two layers of velcro give it some cushion.
Old Sep 17, 2008 | 04:26 PM
davis61381's Avatar
I'm going to have to check it out. Her license plate is not flat so I think that may be part of the problem. When it's attached to the hatch, the bottom right corner is raised off the hatch.
Old Sep 17, 2008 | 04:50 PM
i used some weather strip behind the plate and tightened down the plate.
no rattling on mine.
Old Sep 17, 2008 | 06:35 PM
Juliane's Avatar
Speaking of license plate frames...do you guys take yours off when you wash the car? Because my car is grungy behind the plate.
Old Sep 17, 2008 | 06:37 PM
trancedsailor's Avatar
I don't take mine off when I wash, but I'm ordering the mugen frame and bolts right now so I'll wash behind the plate when I get those.
Old Sep 17, 2008 | 06:40 PM
Cat's Avatar
Cat
I've had the Fit frame and a Mugen one, both rattle. I even tried Fit screws and Mugen ones, they both rattle.
Good idea of securing it to the car. It is a good idea to remove the plate and clean behind it to keep it from getting really dirty. My cousin taught me to also raise the hood and clean that area everytime I wash my car to keep debride and rocks from scratching that painted surface too.
Cat :X
Old Sep 17, 2008 | 06:54 PM
I need to take a wet rag or something to my engine to clean off some dust and stuff. My OEM plate doesn't rattle. Try tightening it down more. Mine's tight as balls, it won't move at ALL.
Hootie's Avatar
Grab two short screws and nuts and just tighten them on there. Make sure the screws are short enough to were they won't scratch the hatch.
Old Sep 17, 2008 | 11:51 PM
Fa1's Avatar
Fa1
no frame ftw
Old Sep 18, 2008 | 02:05 AM
enjoito's Avatar
i have a plastic rear license plate frame doesnt rattle at all.
Old Sep 18, 2008 | 03:00 AM
martymcfly's Avatar
I rammat the entire back side of the plate AND the 4 side between the plate and the frame.
Old Sep 18, 2008 | 09:14 AM
Juliane's Avatar
???? What the heck is rammat???
Old Sep 18, 2008 | 09:26 AM
IfTheFoo's Avatar
Google tells me its sound deadener.Prolly a good application as long as it doesn't degrade over wet/dry cycles.
Old Sep 20, 2008 | 02:07 PM
azul's Avatar
My car has these two rectangular thick foam pieces, maybe 2 inches tall, an inch wide, under where the bottom third of the license plate goes. I've never had a problem with rattling. I thought it was factory, but maybe dealer install?
Old Sep 20, 2008 | 02:15 PM
HONDAMATIC's Avatar
its dealer installed, so its up to the pdi tech to install it
