DC5 helical LSD a direct swap for GD3 manual?
Old Sep 18, 2008 | 06:41 PM
MugenShard's Avatar
Even though Spoon, ATS, J's and others list the Fit LSD as a seperate fitment from the DC5 (RSX), everything I've seen in images makes the differentials from both cars appear identical. Does anyone by chance have the open diff from their Fit available to compare? I have a DC5 helical available to me, just no diff from a Fit without pulling it out.
This would be great news though. I'd love to run a helical LSD over a camlock. Would be worth figuring out.
And, hello forum!
Old Sep 19, 2008 | 05:35 PM
ghostfit's Avatar
I am going to be nice here. No they are not direct swaps. Pictures may look the same but they are just pictures. The transmissions are different, plain and simple. however since you say you have a LSD available for a k series trans. try it on your own car. If it works then u have made a huge discovery
Old Sep 19, 2008 | 05:47 PM
Tofuman's Avatar
No, it will not fit. They might look the same, but they are not.
For example:
Quaife LSD for Honda Fit... Part number: 60.309.140
Quaife LSD for Acura RSX... Part number: 60.309.190
Old Sep 19, 2008 | 06:15 PM
MugenShard's Avatar
As stated, I know the part numbers are different.
As also stated, I was trying to find someone with the open diff out of their fit to help compare, instead of pulling the diff out of my car just to see.
Not rocket science.
By the way, Quaife, Cusco and nearly everyone else assign different part numbers to identical units (for whatever reason) for different applications. Even though the actual diff is the same. That hasn't changed since I bought my first LSD for my first Datsun in..however long ago that was...
Anyways, thanks.
Old Sep 19, 2008 | 07:07 PM
spoonek4's Avatar
Not rocket science.
Anyways, thanks.
I'm pretty sure that it will not fit too. I looked at a stock Fit open differential before & man they're TINY! Even though the shape looks
similar, mounting bolt, spline counts for the drive shafts etc can be very different too.
As I remember the spline counts on the drive shaft is 32. I can double check when I get home tonight. U can pull your drive shaft out to see coz that's the VERY VERY first step to see if that single diff/LSD fits or not.
Hope this helps.
Old Sep 21, 2008 | 03:24 PM
_BEN_'s Avatar
Thumbs up
A little more info.
Comparing pn's (just for sake of listing)
'08 SI LSD: 41200-pnt-003
'05 SI DIFF: 41100-ppp-000
'08 EX DIFF: 41100-rpf-000
'08 Fit DIFF: 41100-pwl-b01
All use the same bearings: 91005-pp5-003
Some use a speedo gear some use the new magnetic trigger system.
Here is a technical drawing of the Quaife EP3 and DC5 series lsd's.
http://www.quaife.co.uk/shop_files/QDF9U57139.jpg
http://www.quaife.co.uk/shop_files/QDF9U2883.jpg
Different links same drawing.
No tech drawing for the fit. Atleast I could not find one.
Parts drawings (no dimensions):
Fit: http://www.slhondaparts.com/images/PCI/14SLN7/018/8.jpg
'08 Si (LSD): http://www.slhondaparts.com/images/PCI/14SVA6/025/7.jpg
'05 Si: http://www.slhondaparts.com/images/PCI/14S5S0/015/8.jpg
'08 EX: http://www.slhondaparts.com/images/PCI/14SVA6/024/8.jpg
Old Sep 21, 2008 | 03:35 PM
spoonek4's Avatar
Originally Posted by _BEN_
A little more info.
OK. I just found that it's 1.0241inch/26.0mm on "D4"(bore) in the Fit LSD's technical drawing, also # of teeth on drive shaft spline is 25. All the other numbers are pretty much the same. But I'm pretty damn sure that the DC5/EP3 LSD will not fit into GD1/GD3's tranny just because of these two factors.
Old Sep 21, 2008 | 05:21 PM
_BEN_'s Avatar
The Fit's differential dimensions may be in the honda service manual. If someone has it chime in.
<-- Stuck at work so I can't really spend too much time searching.
Another thing:
The Fit uses a 10mm bolt while the SI uses a 11mm bolt for the final drive gear.
Old Sep 21, 2008 | 09:33 PM
spoonek4's Avatar
Another thing:
I'm not sure which Si u're talking about. But DC5/EP3 uses the same M10x1.0 bolts as the GD3. And both DC5/EP3/GD3 all uses 10bolts in total.
I doubt Quaife/Honda will make a final drive ring gear that uses different(odd size for Honda) bolt size.
Old Sep 21, 2008 | 10:42 PM
_BEN_'s Avatar
I double checked just to be sure and the '06+ Si's have a 11mm bolt listed for its ring gear.
fyi Im grabbing these numbers from slhondaparts.com
Old Sep 22, 2008 | 12:34 AM
spoonek4's Avatar
Maybe that's the tranny difference between the DC5 generation & the FG/FA/FD generation.
Old Sep 22, 2008 | 03:30 AM
_BEN_'s Avatar
A RSX diff uses 11mm too. Acura Parts @ AcuraAutomotiveParts.org - Genuine Acura OEM Parts from Acura Carland
We need to get a tech drawing for the fit's diff. That will yield the answer.
Maybe the 11mm that is next to the bolts description is referring to its length.
Old Nov 1, 2008 | 10:52 PM
MFactory's Avatar
No, it won't fit due to the axles. Different spline count and bore.
J_L
Oct 19, 2015 02:37 PM
kelsodeez
Apr 23, 2012 04:15 PM
Ragnarok0mega
Aug 24, 2011 10:30 AM
dewthedew
Dec 21, 2009 12:35 PM
porkchop
Feb 28, 2009 03:46 PM
