S2000 fit?
Old Sep 27, 2008 | 07:29 PM
matrix02's Avatar
S2000 fit?
I have (4) S2000 oil filters (15400-PCX-004) left over after I traded it in. I read a forum in here that this filter will work in the Fit. I just wanted to confirm this. Also, is there any problems like leakage or anything.
Old Sep 27, 2008 | 08:37 PM
dank24's Avatar
I doubt anyone has tried to fit a different filter from a different model on their Fit. How about cross matching part numbers and see if they are the same? Or just trying it out yourself?
Old Sep 27, 2008 | 08:49 PM
petwhookie's Avatar
I went to the dealer and they said every honda oil filters were the same besides the s2k and oddesy (not 100% sure about this one).
Old Sep 27, 2008 | 10:07 PM
matrix02's Avatar
this is the link where i found that the s2000 oil filter might work in the Fit.
https://www.fitfreak.net/forums/fit-...t=s2000+filter
just wanting to make sure it will work on the Fit before I try it. Otherwise, I will just put it on ebay.
Old Oct 3, 2008 | 10:53 AM
ArdentAzn's Avatar
As far as fitment, the S2000 filter WILL fit... It is slightly bigger than the ones for 'regular Hondas'... However, I have heard that due to the difference in engine demands, our fits might not have the necessary oil pressure dor the S2000 filters... I don't know how this would affect it, but this is the conclusion I got after hours of research... Hopefully someone can enlighten/explain this???
Old Oct 3, 2008 | 07:05 PM
SYMBIOTIX's Avatar
I used to run s2000 filters on my EP3 all the time. They are a higher quality if you get the right part number - specifically you want the filter made in Hong Kong by Toyo Roki. I think there is another one made for the s2000 by honeywell/fram which is garbage.
Good luck
Old Oct 5, 2008 | 08:41 PM
i usually cross reference via the mobil site on filters. ends up my legacy and
G35C both use the M110, so i can use my nissan filter on the legacy if i wanted
and viseversa. lol (not that i would, but they fit).
Old Oct 11, 2008 | 04:12 AM
HONDAMATIC's Avatar
the only honda ones that are the different ones are the s2000, nsx, legend, 96-98 3.2TL.. I put honda filters on my gfs g20 and other nissans...
Old Oct 24, 2008 | 05:49 PM
Tofuman's Avatar
I know the S2000 filter fits on K20's. I remember reading about it back when I had an EP3. The Fit and the K20 engines use the same filter, so it should fit just fine, but i don't know about the oil pressure issue that has been brought up.
Old Oct 28, 2008 | 07:47 PM
bigg_kidd's Avatar
i am still using the oil filters on my FIT that was on my 05 integra type S, and they fit just fine. that saved me hella money
BenjaminFit
Mar 23, 2011 12:49 PM
Mclaren_Honda
Nov 19, 2009 06:46 PM
Lek
Jul 4, 2009 03:34 AM
kinosh
Sep 27, 2008 10:10 PM
ricohman
Sep 23, 2008 07:14 PM
