Supa-Sucka Installation
Old Oct 15, 2008 | 03:44 AM
fitn54's Avatar
Should be getting my Intake today and will install. James mentions that you have to have your "radio code" before disconnecting the battery? Where is that and how to you get it? Just trying to prepare myself before install.
Old Oct 15, 2008 | 04:56 AM
revd34's Avatar
"radio code" so you can use your head unit again, right?
the dealer should have given it to you already. my code is on a card on a envelope with my owners manuals.
if they didn't include it, you can get it from the dealer
Old Oct 15, 2008 | 11:18 AM
koolkevin1107's Avatar
mine is attached in the glove box on a white sticker. Check to see if yours is there also. it should be a 5 digit #.
Old Oct 17, 2008 | 05:16 PM
07fitsport's Avatar
should got from dealer and maybe on glovebox
Old Nov 12, 2008 | 10:16 AM
H-FIT-James's Avatar
Thanks for your support of H-Fit and H-Fit products,
As for the radio code it should be a white or blue card with your radio security code on it. We suggest that you remove the negative terminal from the battery for safety reasons, but it is not "absolutely" necessary. Removal of the battery makes the chamber installation easier. If you choose to not disconnect the battery then you will not have to worry about your radio code. If you cannot find your code then I would suggest that you just leave the battery connected during the installation. this will prevent headaches with the radio code after installation.
Hope this helps,
Thanks again,
James
H-Fit Team
H-Fit.com ...New Products Available now...
crash001
Jun 28, 2024 07:54 AM
john21031
Feb 23, 2020 06:19 PM
Sheppard
Sep 30, 2017 11:21 AM
mahout
Jun 4, 2011 08:17 AM
Lideusz09
Oct 9, 2009 05:41 PM
