Tire pressure? Do you use the recommended door psi or tire psi?
Old Oct 19, 2008 | 09:57 PM
boots11234's Avatar
I was just wondering what others use for tire pressure in there FIT sports. The tires say 45 psi and the door says 32 psi. Which one should I use?
Old Oct 19, 2008 | 09:59 PM
neteng101's Avatar
Neither. Try 36 front/34 rear (after they have totally cooled down, not right after driving) or something like that for the best results.
And check your pressures once a month - temperature changes affects the pressure in them.
Old Oct 19, 2008 | 10:03 PM
Arkaneinc's Avatar
I've always gone off of Tire Psi.
Old Oct 19, 2008 | 10:04 PM
CrystalFiveMT's Avatar
I'm with you. I currently run 35F/33R measured first thing in the cold morning. I like the ride quality as is, handling/braking is good, steering feel is good and my mileage...can't complain.
Old Oct 20, 2008 | 12:47 PM
ruknight4ever's Avatar
38 PSI for all four tires.....
Old Oct 20, 2008 | 03:15 PM
Tastycakes's Avatar
Wow 38-45 PSI? lol 1st off never go what the tire says, thats the max. PSI for the tire. Go what the car says, 32.
You run anything above that, 32, the center of your tires are gonna go bald due to over inflation and wear out faster.
Old Oct 20, 2008 | 03:21 PM
JDMxGE8's Avatar
I usually run 35 PSI front/rear.
Old Oct 20, 2008 | 03:26 PM
FitCanada_Girl's Avatar
Why run different tire pressures front/rear? Just curious. I'm at 35 psi all around right now...
Old Oct 20, 2008 | 03:54 PM
FITrunner's Avatar
I usally go about 35psi. I know you get a little bit better mpg going higher, but you also ad more wear and tear to the tire. So you choose, pay more for gas, or pay to replace the tires sooner. Hence I don't max out the psi like a few folks have done.
Old Oct 20, 2008 | 03:56 PM
Yeah there's one guy over on the EcoFit site whose running something like 60 PSI!!!!!!!!!!!
Old Oct 20, 2008 | 04:08 PM
txmatt's Avatar
You can do a bit of handling tuning (oversteer vs understeer) via tire pressures. A little more pressure in the fronts helps reduce understeer/push.
Old Oct 20, 2008 | 04:13 PM
FITrunner's Avatar
WTF! 60PSI??!! LOL Bet they get good mpg though haha! I don't think the spare donut even takes 60psi. I better check it before my road trip next week lol.
Old Oct 20, 2008 | 04:15 PM
TWGE08's Avatar
Does the sticker say 32psi or 33? I swear I thought it was 33 psi.
Old Oct 20, 2008 | 04:17 PM
Thanks for explaining! + Rep
Old Oct 20, 2008 | 04:18 PM
Silly me, he's now at 65 PSI...no kidding! It's this guy "pb and h"
33 psi for Sport, 32 psi for base
Old Oct 20, 2008 | 04:59 PM
neteng101's Avatar
Car is front heavy - front engine front wheel drive. The higher pressure helps compensate the most when cornering as most of the load is on a single front tire at that point, thus improving the handling a bit.
The only time you want to possibly bump up the rear is if you know you'll have an extended trip with a laden down car.
I would never ever run tires at the sidewall PSI.
Old Oct 20, 2008 | 05:05 PM
Even better explanation (no offense)! More +rep....
So what do people recommend? 35 psi front and 33 psi back seems "reasonable" to me...
Old Oct 20, 2008 | 05:35 PM
feddup's Avatar
45
45 all around. Mine's an 08 and the Dunlops say 51. Yeah I know 45 is very high. Guess what I put a high priority on mileage and yes it makes the ride more harsh! That's measured cold in my garage by the way.
The general "rule" is a few psi over the factory recommended specs. 33F/R is going to be more on the conservative side and skews a little toward ride comfort. I say if you're anything above 39 psi cold, your handling/braking/ride/tire wear/steering feel will suffer. But to each his own.
You may want to experiment for yourself and see what setting you like.
