Installed! 9 LED Line Beam
Old Oct 25, 2008 | 01:24 AM
ACfit's Avatar
Lightbulb Installed! 9 LED Line Beam
Just installed these 9 LED line beams today. Installation was SUPER EASY.
They are IMO better than J's S-tai due to the nice looking exterior and ease of installation.
It comes with a mini ballast type module and you only need to connect the RED wire to + terminal and BLK wire to - terminal. NO NEED TO INSTALL ANY SWITCH. It magically lights up when you turn on ignition and shuts off when you turn off your ignition!
That's all the wiring there is to do !!!! I couldn't believe this myself!
Old Oct 25, 2008 | 01:35 AM
enjoito's Avatar
oh nice man i seen that in autobachs in japan i was about to buy it. i should of its sick
Old Oct 25, 2008 | 01:46 AM
Lunar_GD3's Avatar
So its not a fused line ( looks like their might be an inline but hard to tell) and is just connected to the battery alone? Hmmm still dont see how it can auto turn off and on, maybe since its waiting for the charge in the battery when the alt connects. But enough rambling, I think it looks cool man. Watch out for the 5-0 that blue could be trouble.
Old Oct 25, 2008 | 02:44 AM
alexfree05's Avatar
where did u buy those?
and what else colors
Old Oct 25, 2008 | 09:07 AM
FELIXY69's Avatar
i had j's racing blue LED before....and i got 3 VI in Richmond because of it..so i took it off after the 3rd time...
good luck with yours ... i hope u don't come into richmond...other wise becarefullllll
Old Oct 25, 2008 | 03:34 PM
ACfit's Avatar
They actually look more white than blue. Probably just the way they look in photo. There is a different part # for blue. Thanks for the heads up
I believe that little ballast is a micro-chipped interrupter circuit of some sort.
I ordered direct from Japan. But the minimum order was 10 Luckily a friend is going to grab 2 sets off me.
Old Oct 25, 2008 | 10:50 PM
SD_MR_FIT's Avatar
how much do you want for a set?
i need some for my girls civic.
itll be my easy way for fogs heh.
Old Oct 25, 2008 | 11:36 PM
alexfree05's Avatar
i want a set too =]
Old Oct 26, 2008 | 12:55 AM
martymcfly's Avatar
Can this be used as DRL? I am interested for a set.
Old Oct 26, 2008 | 03:31 AM
ACfit's Avatar
It works great as a DRL. That's why I got this too, because I don't have DRL after Bi-xenon put in.
Old Oct 26, 2008 | 04:56 PM
Arkaneinc's Avatar
how much for a set? if your looking to get rid of a set I'd be interested.
Old Oct 27, 2008 | 01:12 AM
fitster's Avatar
me too im in coquitlam i can pick up a set asap
Old Oct 27, 2008 | 02:26 AM
ACfit's Avatar
I didn't expect so many ppl to be interested in my leftovers. I plan to keep an extra set for myself. So I have 6 sets avail. Plz pm me.
Old Oct 27, 2008 | 04:52 AM
wobuffet's Avatar
i'm interested in a set as well.
i'm in richmond at least 5x a week, so that'd work out fine!
pm me # and price
thanks
Old Oct 27, 2008 | 06:24 PM
ACfit's Avatar
More Pictures.......
First picture --> I stuck the mini ballast thingy with the double sided tape supplied
middle picture --> I used the instructions as a guide to position the placement of the lights. Note that the angle of the lights can be adjusted. I pointed mine straight ahead. Simply stuck on the bottom with supplied double sided tape (pretty strong) or you can also tap screw on bumper.
last picture --> green line that's drawn denotes how I run the wires. There's this black plastic cover that you can tuck the wires into. That's also where I tucked in my HID bi-xenon wires.
Will post far night shots soon.
Old Oct 27, 2008 | 11:52 PM
SD_MR_FIT's Avatar
so you only have the blue ones?
Old Oct 28, 2008 | 02:15 AM
ACfit's Avatar
I only have white ones. I think the camera's white balance was thrown off by the fluorescent tubes in the parking lot.
I looked at them again and confirm again that they are white... they matched up very closely to my 6000k HIDs.
Old Oct 28, 2008 | 03:47 AM
fung88's Avatar
Led Lights?
quite interested in the lights ..
how much are you sellin for?
Old Oct 28, 2008 | 03:12 PM
aliencowboy's Avatar
Price shipped to 91042 So Cal
Thanks AC
Old Oct 28, 2008 | 05:54 PM
SD_MR_FIT's Avatar
6000k has a hint of blue. its cool...
ill let you know when i can get that money to ya.
