Running water sound when stopping/moving
Old Nov 16, 2008 | 08:21 PM
jdzz's Avatar
During braking and accelerating, I can hear a feint water moving sound under the dash(center console). Do you know what might cause this. This car was never flooded. I am guessing it has to do the a/c system, but don't know where to start. This is a 2007 Fit.
Thank you
Old Nov 16, 2008 | 08:35 PM
Super Mario's Avatar
It's your gasoline slushing around. Sounds like a stomach full of water right? It's normal.
Old Nov 16, 2008 | 08:54 PM
doctordoom's Avatar
Supervillain
Yeop yeop. Gas tank is located approx. underneath your seat.
Old Nov 16, 2008 | 09:52 PM
solbrothers's Avatar
you are sitting on your gas tank. if you remove your console, you fuel pump is right there
Old Nov 17, 2008 | 11:20 PM
jdzz's Avatar
Thanks, hopefully it is the cause because I only hear it recently.
Old Nov 28, 2008 | 05:31 PM
lamyun's Avatar
If the sound is from the centre console, you are probably low on coolant. Check that first.
Thank you
Old Dec 20, 2008 | 10:43 PM
kinosh's Avatar
I was low on coolant once and heard a water-draining sound towards the front of the car IN ADDITION TO the sloshing of the gas underneath the front seats during braking and acceleration. The sounds were different.
Old Dec 21, 2008 | 03:23 PM
usmc0341's Avatar
yeah it's more than likely the fuel tank...even the new accords make the same noise
Old Dec 21, 2008 | 09:46 PM
jdzz's Avatar
Confirmed, It is the coolant. Thank you guys.
Old Dec 30, 2008 | 07:03 PM
fithouston's Avatar
i've been hearing the same noise for about 2 weeks, just read this tonight, checked the reservoir and it looked empty. thanks hopeffuly the radiator wasnt empty and that i didnt do any damage.
Old Jan 8, 2009 | 10:54 AM
Sol705's Avatar
had the same problem for a few weeks. Took it in to the dealership. They bleeded out the radiator and the problem went away.
Old Jan 8, 2009 | 04:01 PM
willy65000's Avatar
does anyone know how to bleed out the cooling system?
aZnCdn
Feb 19, 2014 09:32 PM
riff42
Dec 28, 2011 03:35 PM
sax2play1
Sep 10, 2009 08:09 PM
fishman
May 20, 2008 08:31 PM
angelberybblgum
Oct 4, 2007 09:00 PM
