Anyone running aggressive fitments?
Old Nov 19, 2008 | 12:06 AM
RIMTUCK's Avatar
Question Anyone running aggressive fitments?
Is anyone here running on aggressive wheel fitments?
Old Nov 19, 2008 | 12:28 AM
redrumm's Avatar
some not most
all i know is someone needs to run these
Old Nov 19, 2008 | 12:29 AM
MNfit's Avatar
Yea there are plenty of people running an aggressive wheel fitment. I know FELIXY69 is for his VIP style Fit. and I AM RAY has run low offsets before, I think he might have even done +0mm or damn close to it. I think Fit4trav has +15mm offset as well. That's three people right off the top of my head and I know there are others, so yes there are people running aggressive wheel fitments.
Old Nov 19, 2008 | 07:51 PM
User Name's Avatar
yep
Ummmmm yep
Old Nov 19, 2008 | 08:09 PM
randay's Avatar
Originally Posted by redrumm
some not most
i would totally run those. 24k gold even.
Old Nov 19, 2008 | 08:56 PM
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
A search would and wouldnt help you. It wouldnt help you as a hand full run lower offsets. But it would help you as there are a few running low offsets.
Best fitment IMO, is a 30 to 25mm offset in a 15x7 or 15x8in wheel.
It all depends on what you want?
Old Nov 19, 2008 | 10:37 PM
Gd3_Derski's Avatar
When comparing 15x7 and 15x8 with lets say a 25 offset...where does that inch effect? Lol...
Old Nov 19, 2008 | 11:15 PM
Fit4Trav's Avatar
^^^Well a 15x7 +25 wheel would be 1" shorter width wise from a 15x8 +25. The main difference though would be where the wheel mounts on the hub. With some simple calculations 1" roughly equals 25mm. so a 15x7 w/ a 0 offset would sit exactly how a 15x8 +25. Again this is a rough estimation you would still have to take into effect back spacing and some wheel manufacturers make a low disk, super low disk, and normal disk, which also affects how the wheel sits on the hub.
Hope that makes some sense.
Thanks for coming to the boards Rim Tuck. I am CamoTrav on bBSquad. Welcome.
Old Nov 19, 2008 | 11:38 PM
Kyle is raaddd's Avatar
Master FitFaker. CHEA!
i wanna see some -offset.
someone do it
Old Nov 20, 2008 | 02:37 PM
kifu's Avatar
Close but not totally correct. Offset is measured from the center line of the rim to the mounting face. If you use the 7" and 8" wide wheels as an example, if both wheels have a 0mm offset (the mounting face is directly in line with the wheel's center line) the edge of the 8" rim would sit 1/2" further out toward the fender AND 1/2" closer to the fender well/suspension. This is a very useful for figureing out wheels sizes and offsets. Wheel / tire size calculator / comparer - RIMS-N-TIRES
Old Nov 20, 2008 | 02:39 PM
JDMxGE8's Avatar
Going too aggressive with the offset can really damage your suspension.
Old Nov 20, 2008 | 04:21 PM
redrumm's Avatar
so can springs with stock shocks
Old Nov 20, 2008 | 05:05 PM
JDMxGE8's Avatar
A little obvious don't you think? Any experienced car enthusiast would know that.
Old Nov 20, 2008 | 08:48 PM
Fit4Trav's Avatar
Bingo!!! That's what I was trying to say
Old Nov 20, 2008 | 08:49 PM
Fit4Trav's Avatar
How so? I have never heard this?
Old Nov 20, 2008 | 08:55 PM
JDMxGE8's Avatar
Going too aggressive puts a large amount of stress on the control arms, axles, etc. It really depends on the vehicle. AE86 and Miatas are fine with extremely low offsets.
Old Nov 20, 2008 | 09:30 PM
Posts in the NUUDE
The only thing it really puts stress on are wheel bearings.
Negative offsets on the Fit is too much. If you want a nice stance go wider with a higher offset (+30mm) or not so wide with a lower offset.
From previous wheels Ive had 25mm is the lowest Id run.
Even that involves rear 1/4 rolling and some front fender rolling/pulling.
Old Nov 25, 2008 | 02:24 AM
Fit4Trav's Avatar
My next wheels I wanna go 15x8 +10 =) in the rear and 15x8 +25 in the front
Old Nov 25, 2008 | 10:53 PM
Gd3_Derski's Avatar
Thx guys...i understand now...question now is handling...which is better? X8 or x7?
Old Nov 26, 2008 | 12:46 AM
Fit4Trav's Avatar
Well...I may be completely wrong, but I would say a x8 wheel would be better because there would be more contact with the ground.
