Spring Install
Old Nov 26, 2008 | 09:24 PM
Flyin172s's Avatar
Spring Install
So, I can't ever find anything with the search function. Sorry if this has already been covered.
I put new springs on my Fit and now the ABS light is on. The manual says it means the ABS isn't working and to take it to the dealer. For obvious reasons, I don't want to bring it to the dealer, is there anything I can do to fix it? Or should I just bring it to my mechanic.
Thanks for the help.
Old Nov 26, 2008 | 09:52 PM
gimme's Avatar
Master FitFreaker
ABS???? installing springs has ZERO to do with the ABS,,,,,have you tried to reset the ecu?
Old Nov 26, 2008 | 09:56 PM
kylerwho's Avatar
spoon fed
to install the springs there are those little elecrtonic clips you have to unplug on the strut. unplug them again and blow them out and make sure they are plugged in good again. then unplug the battery for 5 minutes. replug the battery and turn the car on. this should hopefully solve your problem. +rep for questions
Old Nov 27, 2008 | 05:29 AM
HONDAMATIC's Avatar
that or you messed up the abs sensor wire by letting the knuckle hang
j's_fit
Sep 6, 2011 10:36 PM
RandomKoko
Jan 23, 2009 04:51 AM
unphit
Dec 7, 2008 01:23 AM
untx3
Aug 16, 2007 02:29 PM
TAKUSITO
Oct 11, 2006 05:17 PM
