headlight dimming when defroster comes on?
Old Jan 7, 2009 | 10:48 PM
runbikerun's Avatar
Anyone having this issue? My headlights seem to dim when the defrost/ac kicks on. Is this normal?
Old Jan 7, 2009 | 11:12 PM
Sid 6.7's Avatar
Why so serious?
The alternators are rather weak, and the Fit uses a lot of amps. I am noticed it lately on cold rainy nights when running my new 90/110w H4 bulbs, fogs, wipers, rear defrost, aftermarket head unit, sub/amps, front defrost/fan, turn signals. Even the power steering pump is electric.
You might find the lights brighten up and stay bright if you install a large gauge grounding kit.
Do a search here on FF.net and Google for "Earth grounding systems". You can purchase a pre-made earth grounding kit, or just buy 25-30' of 1/0 or 0 gauge copper wire and some large ring terminals and make a kit for yourself for the cheap. You should be able to buy the large gauge wire at a welding supply store (no doubt one of the lower priced sources of big gauge durable wire), or even a place like Best Buy or a stereo shop.
Old Jan 7, 2009 | 11:52 PM
runbikerun's Avatar
Thanks, I'll get on it.
btw. Just saw the Dark Knight. Excellent Movie!
Old Jan 27, 2009 | 06:33 PM
wolfbuddy's Avatar
the earth grounding system shown in the thread has been discontinued
Old Jan 31, 2009 | 12:24 AM
DarkFit's Avatar
Yeah your lights will also dim if you try rolling your windows up/down. So that's not uncommon for Fits lights to dim because of turning something on.
Old Feb 13, 2012 | 01:35 AM
GoFits's Avatar
Yeah mine will dim and even PULSE when I have the A/C or heater on. This gets annoying at night on the highway or when you're in traffic when it becomes obvious by the lights reflecting off the road surface and the tailgates in front of you. I thought it was the alternator going out at first....I may try a grounding kit if it will eliminate the pulsing.
F..it
Sep 3, 2020 07:52 PM
NBPFIT07
Feb 26, 2011 05:49 PM
d_clouse04
Jan 13, 2011 08:20 PM
sterVin
Sep 12, 2008 11:40 PM
Tony Baker
May 4, 2005 04:44 PM
