Help!!!!!!! Crank pulley bolt
Old Jan 10, 2009 | 05:29 PM
Squad808 Fit's Avatar
I need help getting my crank pulley off. I tried every possible way to get it off. I already am ghetto riggin it, used air tools (MAC 1/2), breaker bar and 1/2 in extention (ended up bending extention). I already know how to stop the pulley from moving, I JUST CANT CRACK THE BOLT OFF. PLEASE HELP, Which way does the bolt come off?
Old Jan 10, 2009 | 05:58 PM
xaircooledx's Avatar
Honda is known for using some un-earthly glue on their crank bolts. The first time you take them off, blasting it with a flame will melt the compound and you can take it off using regular tools.
Old Jan 10, 2009 | 07:02 PM
kylerwho's Avatar
spoon fed
turn it counter clockwise to twist it off. i used a breaker bar with a three foot cheater pipe and really pulled on it and it popped really loud so i though it broke the bolt but it came off finally.
Old Jan 10, 2009 | 07:39 PM
koolkevin1107's Avatar
Craftsman 350ft/lbs torque impact gun in reverse ftw!! I could only use power tools, couldn't do it with hand.... wayyyyy tooo hard. OH and i tried it with a 250ft/lb impact gun and it didn't move. the 350 worked like a charm.
Old Jan 10, 2009 | 08:38 PM
artieman's Avatar
My snap on atc500 impact gun ripped it right off. But with 600ft lbs in reverse it wasnt much of a suprise.
Find someone with an impact gun with some balls.
Old Jan 10, 2009 | 08:41 PM
kylerwho's Avatar
spoon fed
so how big are the balls of a guy who did it by hand?
Old Jan 10, 2009 | 09:21 PM
thanks
THANKS GUYS! I got it off, took it to my friends shop and it went right off. Found out that our compressor is not putting out enough psi, but the guns we had were semi truck air tools. My friends all work with the big rigs. Anyway, THANKS.
Old Jan 18, 2009 | 03:11 PM
djboi808's Avatar
if you can get your hands on a 3/4" impact gun that will take it off . trust me i was working on hondas everyday for the pass 10 years and my 3/4" impact gun never failed
Old Jan 19, 2009 | 03:52 AM
Steven Hung's Avatar
If the 3/4" impact gun failed, there is the 1" impact gun with over 1,500 ft lbs of torque. My friend owns a repair shop in Brooklyn NYC and he rarely uses the 1” impact gun.
Old Apr 26, 2009 | 02:39 AM
flowmaniacscrew's Avatar
how did you stop the pulley from moving?
Old Apr 26, 2009 | 03:33 AM
If you use an impact gun, you dont need to worry about the pulley moving. Just letting you know that the bolt is VERY VERY tight. I couldnt get it off with my compressor, using a diesel impact(gun is very srong), So i took it my friends shop, took it off with ease.
If youre doing it by hand tools, you will need the special honda pulley tool (google it). It holds the pulley by the tool being put over the bolt, connecting the tool to a breaker bar, then you can loosen.
Here's a video: YouTube - Auto Repair - Honda Crank Pulley Tool Use
These are the only ways that are possible without damaging anything. GOODLUCK!
Old Apr 26, 2009 | 02:48 PM
oh that tooll. aright, do they sell it anywhere than online?
Old Apr 26, 2009 | 05:23 PM
Nope, but u can try honda or acura, or even ask someone that might have it on honda-tech to let you borrow, this way you save money. Youre probably going to use it 1 time.
Old Apr 26, 2009 | 05:32 PM
im the fit's Avatar
I torched the bolt for a couple of sec's and used a electric/air tool 200lb and came right off
Old Jan 16, 2010 | 03:10 PM
J_L's Avatar
J_L
I'll bump this old thread with a question:
Assuming I get the pulley off with the special hex tool, how to tighten the new pulley that does not have the hex insert? Impact wrench only? I'm kind of leery of wedging something in the pulley hole to hold it while tightening the bolt.
Old Jan 17, 2010 | 11:47 AM
fit2bking's Avatar
Put the tranny in Gear, have a friend apply the brakes
and torque the bolt to specs!
The secret to removing the pulley is to make sure the engine is HoT!
No need for any special tools, use an impact wrench or breaker bar,
again with a hot engine!
Old Jan 17, 2010 | 02:56 PM
J_L's Avatar
J_L
Putting my auto in gear isn't going to hold that crank shaft. What have the auto folks done?
Old Jan 18, 2010 | 12:25 PM
fit2bking's Avatar
It should hold, especially if you apply the front brakes!
This is what has always worked for me...I have done
this on 3 fits, all A/t
Old Jan 18, 2010 | 01:14 PM
J_L's Avatar
J_L
That's surprising, thanks for the info!
Old Jan 18, 2010 | 07:28 PM
raton's Avatar
My buddy tried using his normal impact gun (650 ft-lb I think)...failed no matter what we tried.
He ended up getting a 1100 ft-lb impact gun (Ohio Power Tool - Ingersoll-Rand 1/2 Inch Titanium Duty Impactool 2135TiMAX)....sucker came off in 4 seconds!
