OBX header
Old Jan 19, 2009 | 11:58 PM
im the fit's Avatar
OBX header
is any one else using this headerName:  img076.jpg
Old Jan 20, 2009 | 12:05 AM
kylerwho's Avatar
spoon fed
there was a local guy around here that had one. its an ok piece. kinda like a megan header.
Old Jan 20, 2009 | 12:06 AM
AnlDyxp_GD3's Avatar
I remember reading a discussion on this header before. OBX has some fitment issues if i remember correctly. But i'm sure the header performs as intended, OBX's products cost way less than most. I was considering their exhaust for the Fit a while back.
Old Jan 20, 2009 | 12:07 AM
kylerwho's Avatar
spoon fed
i helped the guy install it and it fit good. its just a cheap header. nothing special about it. you do need to weld on an o2 bung on the header though cause the company copied a jdm version header.
Old Jan 20, 2009 | 12:13 AM
im the fit's Avatar
well im using this header with a megan down pipe, i had it for 10k miles so far and no problems,i just want to know what will be the best upgrade.
Old Apr 6, 2009 | 10:26 AM
F*iT's Avatar
I have that header it has ok fitment. the big problem is the mid pipe that comes with it is a cat delete and its designed so you cant use the factory mid pipe with the header
rickshatch
Oct 9, 2017 10:28 PM
tr-yama
Nov 20, 2011 12:13 AM
dewthedew
Apr 29, 2010 08:51 PM
kevinkidstar138
Feb 23, 2010 07:24 PM
