crank pulley removal?
Old Feb 5, 2009 | 10:17 AM
im the fit's Avatar
What is the best way to remove a crank pulley without special hex tool.
Old Feb 5, 2009 | 11:09 AM
gimme's Avatar
Master FitFreaker
impact gun. but that uses a socket, not sure if that's what you consider a "special hex tool"
Old Feb 5, 2009 | 01:46 PM
im the fit's Avatar
The "special tool " im talking about is the one that hold's on to the crank pulley and you put your 19mm socket in the center of it.
Old Feb 5, 2009 | 03:31 PM
kylerwho's Avatar
spoon fed
honda has a crank pulley tool but its like 20 dollars. i just stuck a pry bar in the oem pulley slots and took a nice breaker bar with a cheater bar on it and twisted it off.
i would recommend using an impact wrench though cause that bolt is on there way tight!!!
Old Feb 5, 2009 | 05:35 PM
Sugarphreak's Avatar
Push My Button
The best way to pull it off is with an impact gun rated for 450ft/lbs or more.... TRUST ME!!
Old Feb 5, 2009 | 09:28 PM
Spooling's Avatar
1. Crank pulley bolt holder
2. Apply torque
Old Apr 23, 2015 | 08:20 AM
Myxalplyx's Avatar
Bump
**Old Thread Revival**
I know this is an older thread but I don't like starting new ones if it's not needed.
Does anyone know how I where I can order the crank pulley removal tool (The part number) from? I don't mind it being $20.00 or what not. I just want to have it removed safely and quickly when I'm ready. Thanks!
Edit: Nevermind --> I found this.
Powerbuilt 648796 Honda Cranks Pulley Removal Tool - Pry Bars - Amazon.com Powerbuilt 648796 Honda Cranks Pulley Removal Tool - Pry Bars - Amazon.com
Thanks!
Old May 22, 2015 | 08:10 AM
devmail's Avatar
I ended up paying a mechanic to do this and they had to use the heat of a torch to help them get it off. What a bugger! I tried myself using the chain/hex key method on youtube, effer wouldnt budge, almost gave myself a hernia.
Old May 22, 2015 | 08:52 PM
Rollerboots666's Avatar
I just did mine the other day without the special Honda pulley removal tool.
Years back I use to just stuck a pry bar in the fly wheel and break the bolt loose with a breaker bar and cheater extension if needed. Well this time it was a little different. First thing i did was use some PB Blaster on the bolt. Then I wound up using a ball joint fork tool and wedged it in the fly wheel teeth with the one end in the trans and the other under. This looked the flywheel allowing me to break it loose with a breaker bar (without a cheater extension). Honestly pretty easy.
99ls1tj
Sep 21, 2018 10:00 PM
Rogue_Fit72
May 4, 2018 11:29 PM
07fitsport
Dec 10, 2009 12:58 PM
Fit of RAGE
Sep 1, 2008 12:35 PM
justinreigle (at) gmail (dot) com
May 4, 2005 11:16 AM
