wheels spacer?
Old Feb 27, 2009 | 04:16 PM
Will I Am fit.'s Avatar
Formerly "bitoy"
wheels spacer?
So what's the maximum measurement you can put on the fit? or is 3mm spacer still safe to put on to bring down the offset?
Old Feb 27, 2009 | 09:46 PM
caloyski5's Avatar
i use a 1/4 inch spacer up front. still relatively safe
Old Feb 27, 2009 | 09:53 PM
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
Im not 100% sure, but I think a 10mm spacer can be ran on the Fit and have enough stud left to tighten the wheel down safely. I highly suggest torque them down to specs.
I havent tested it, but I shaved down 1/4in of my OEM wheel studs a while back and I havent had a problem.
5mm can be done with no problems.
Old Feb 27, 2009 | 10:03 PM
Formerly "bitoy"
aight thanks guys, I just ordered the t1r spacer 3mm..
Old Feb 27, 2009 | 10:53 PM
solbrothers's Avatar
just make sure you have 6-7 turns on the lugnuts
Old Feb 28, 2009 | 01:36 AM
Posts in the NUUDE
3mm spacers arent even worth the money. And Im removing one of your sig pics.
Resize please.
Old Feb 28, 2009 | 08:10 AM
ilovemyGD3's Avatar
im currently on 8mm spacers w/ HX rims.
Old Feb 28, 2009 | 08:27 AM
Formerly "bitoy"
Resize please.
cool no probs. I guess your right might as well get the 5mm instead thanks.
Old Feb 28, 2009 | 02:11 PM
Posts in the NUUDE
8mm? So 10 can be done with no problems?
Guess my guess was right.
How many turns did you get on the lug stud?
Old Feb 28, 2009 | 02:37 PM
petwhookie's Avatar
damn the majority of you guys rock spacers without extended wheel studs?
Old Feb 28, 2009 | 02:42 PM
Posts in the NUUDE
You dont need extended studs. 5mm spacers are nothing. The guy above is on 8mm and Im sure 10mm can be done also. The Fits OEM studs are pretty long.
Im running 2 8th gen Civic studs and theyre the same length as my OEMs; which I shaved down a 1/4in.
Old Feb 28, 2009 | 04:03 PM
you dont necessarily need extended studs. as long as you get 6-7 turns onto the threads
Old Feb 28, 2009 | 04:18 PM
TheImmortal's Avatar
make sure the spacers allow u to keep the car "hubcentric"
Old Feb 28, 2009 | 04:36 PM
ehhhhhhhhhhhhhhhhhhhhhhhhhhh. im mr safety, but i dont believe in hubcentric rings and such. most wheels ive seen and used are lugcentric
Old Mar 1, 2009 | 12:01 AM
FitVic's Avatar
i was thinking of getting some spacers for my car too. HmMm................ BTW could someone school me on the 'hubcentric' vs 'lugcentric'. I kinda understand what they do but i just need reassurance
Old Mar 1, 2009 | 12:43 AM
our cars center the wheels on the lugs.
newer toyota aluminum wheels are hub centered.
Old Mar 1, 2009 | 12:45 AM
Formerly "bitoy"
Hmm now I'm torn between 5mm and 10mm I'll be running a +43 offset 15x7 I know 5 will bring me down to +38 and 10 to +33
I've searched and found this about hub centric and lug centric here's the link
Hub Centric vs
Old Mar 1, 2009 | 02:12 AM
FitVic's Avatar
thanks bitoy. I'm checking out the link now. hmm roll your fenders and tuck the fender liner. You should be good with 33mm offset little rubbing doesn't hurt
Old Mar 1, 2009 | 02:16 AM
FitVic's Avatar
now my mechanic said that i really dont need the hub centric pieces but if i start to feel minor vibrations and it annoys me then i should get the pieces to minimize the vibration. It makes sense to me, just right now i gottta wait for my bolts from a fellow member here *ahem* and then set my coilovers to how i want it and get ANOTHER alignment.... (stupid accident) then i guess i'll know if i need em or not
Old Mar 1, 2009 | 12:23 PM
Posts in the NUUDE
For people that are deciding on non hubcentric and hubcentric spacers; non hubcentric can easily be put in place as hubcentric. Put the spacers on the car, center them as best as you can and tape them on the hub to hold them in place. Install the wheel and torque to spec.
The tape and wheel will hold the spacer preventing high speed vibrations.
Out of all my wheels I only used one set of centering rings. Only reason why I ran them was because they came with the wheels and they were drilled.
Ive used OEM lugs on aftermarket wheels and aftermarket lugs on OEM wheels. Its a fad.
Do what you want.
