Coolant change
Old Mar 16, 2009 | 09:00 AM
sonicsc1's Avatar
Coolant change
hello all what is the life span of the coolant for a 2007 fit sport? im at 35 thousand right now thank you
Old Mar 16, 2009 | 05:39 PM
spreadhead's Avatar
I'm at 55K miles, the change coolant code hasn't poped up yet.
Old Mar 17, 2009 | 08:12 PM
Carbuff2's Avatar
The blue Honda Type II coolant has NO silicates and is an HOAT type.
It lasts a LONG time.
On older cars (like our 2006 V) the owners manual specifies a six year 120K mile change cycle. (You change it more often after that because you can't get it all out)
Old Mar 26, 2009 | 10:53 PM
Tarvaln's Avatar
seems I'm dry
It seems (as in it's hard to tell where my coolant levels are) that I'm low on coolant. If that is the case do I have to use Honda Type II coolant or is there anything else (cheaper) that I can use that won't corrode my radiator?
Old Mar 27, 2009 | 03:21 AM
joe bloggs's Avatar
I would stick with the honda stuff, Ive used it and it seems to be just normal blue coolant.
It comes ready mixed so that's handy just pour it in.
If you can find something else then theres the problem of colour and 'will it mix ok'
Old Mar 28, 2009 | 10:32 AM
Carbuff2's Avatar
Shine a flashlight behind the reservoir bottle to make it easier to see the level.
I just got a gallon of 50-50 premixed Honda coolant for $12. I would stick with the Honda stuff.
If the reservoir is dry, re-check after a couple days...you may need to add more.
spookyneo
Nov 20, 2017 12:05 AM
Kishore
Jul 3, 2011 11:42 AM
Crawly
Mar 4, 2010 06:14 PM
mmdir2005@yahoo.com
Oct 17, 2005 03:37 PM
TeGGeR®
Jun 27, 2005 08:22 AM
