Another offset question... with spice!
Old May 1, 2009 | 03:09 PM
Scaldy's Avatar
Advan RGII in 17x7.5, 4x100, 41 offset, 215/40R17 Tires
Will this poke?
I have seen Volks, with a 43mm offset with the same above specs, fit close to flush when lowered on T1R's. I'm not sure if they needed to play with the camber though.
Here's the Advan's on the AJR GD.
Aaand the spice
Old May 1, 2009 | 03:11 PM
Chawee's Avatar
Will this poke?
Aaand the spice
I don't know, but this just made me laugh. Thanks. Good luck finding out that information.
Old May 1, 2009 | 03:18 PM
projekz's Avatar
I think it'll be fine. I test fitted some +40 wheels with some 205-45-17 and not problems.
Old May 1, 2009 | 05:44 PM
qbmurderer13's Avatar
You'll be fine +41 is nothing. Worst case scenario just roll your fenders a bit.
Old May 1, 2009 | 08:00 PM
BakedCookies's Avatar
you will rub, but prob not bad. I rub on big dips and bumps with 205's and +43s
and there is nothing wrong with poke as long as you can get it to tuck on compression. I plan to space mine out some once some decent coilovers hit the US market.
Old May 1, 2009 | 09:44 PM
blackvitzrs's Avatar
remember the wheels he's asking about has a width of 7.5" not 7". THe same 41+ offset on a 7.5" vs a 7" will cause the wheel to be pushed out a tiny bit more.
mikeGe82012
May 28, 2017 12:11 AM
B-Blue
Apr 13, 2010 08:53 PM
bebop.fey
Mar 3, 2009 05:53 PM
rvall004
May 20, 2008 04:08 AM
J.P.
Feb 21, 2007 01:48 AM
