RS*R TI2000 Super Down Springs on SALE!!!!
Old May 20, 2009 | 09:13 PM
stalonehong's Avatar
Hey guys!
For those who are trying to get the RS*R TI2000 Super Down Springs...they are on sale now.
RS-R Ti2000 Super Down Suspension GE8 Fit RS CVT
I know I'm picking up a set of these.
Old May 20, 2009 | 09:18 PM
qbmurderer13's Avatar
Nice. Those have the best drop possible on springs. I just didnt want to wait the 3 month waiting time after you order them.
Old May 20, 2009 | 11:13 PM
MugenAP2's Avatar
Might as well hold off for some coilovers at that price... Just buy the T1R's and when coilovers come out flip the springs and buy coilovers!
Old May 20, 2009 | 11:17 PM
dela's Avatar
holy crap! 500+ for just springs???
i got GC sleeves for cheaper then 500... and u get to choose custom spring rates and its adjustable height
Old May 21, 2009 | 02:40 AM
really?
u got the link?
Old May 21, 2009 | 02:38 PM
BakedCookies's Avatar
How low can you go on the GC sleeves? I have used Ground Control on a few cars in the past and loved them.
Old May 21, 2009 | 02:43 PM
MugenAP2's Avatar
I would have to agree when I had ground control in 1999 they were great. I had them with the 5 way adjustable tokico's and you could not get a better combo than that.
Old May 21, 2009 | 09:49 PM
09fitboi's Avatar
Sorry, I'm a noob, but what is ground control and how does it work?
Old May 21, 2009 | 10:28 PM
dela's Avatar
OP sorry to thread jack... thanks for the heads up on the RSRs..
just basically a spring replacement with adjustable height
these arent the fit ones.. but it'll give u an idea..
they can go pretty low... though not as low as D2s..
as of right now i dropped it a good 2+ inches (dont know the exact drop, but i can go out and measure from the center of the wheel to the fender if u'd like)... i can still go about .75" more in the front and .5" in the rear...
now i just wish koni came out with their yellows or something like them for the GE... if someone is thinking about GC sleeves for the purpose of getting SLAMMED, i'd just lower the spring rates a bit... the spring heights im using are the recommended min...
the springs im using are
front: 6.6kg/mm (375lbs/in) - 2.5" width - 6" height
rear: 3.2kg/mm (175lbs/in) - 2.5" width - 8" height
note: my sig needs to be updated... that was stock height...
Old May 22, 2009 | 03:37 AM
danielg's Avatar
That's pricey for springs...
btw DELA u got PM
Old May 22, 2009 | 04:44 AM
dela's Avatar
for all that are interested, including the OP
Ground Control Suspension Systems
Originally Posted by stalonehong
really?
u got the link?
Old May 22, 2009 | 04:49 AM
kevvur's Avatar
wtf....$600 and that's the sale price?
Reason why I'm getting springs is the relatively cheap price to give me a drop in my ride height. If you're going to spend more then $400 then you might as well save up and get a coilovers when you have the money.
Old May 22, 2009 | 10:37 AM
i was initially thinking about the gc too because my previous set up for my scion tc was the gc and the koni yellows. the drop wasn't as low as i wanted to be so i wanted to try something else.
are you riding ur gc with oem shocks?
Old May 22, 2009 | 01:10 PM
dela's Avatar
yeah on oem shocks at the moment... not much available at the moment for adjustable shocks...
as per the drop... personally, i've only seen 2 GEs with coilovers, RSR coilovers on Dave's (JDM_DOHC_SiR) and D2 coilovers on Note's (ghettoboy247)... the GCs can reach Dave's height, but im not sure if he's totally dropped... and D2s are known to get LOW... i doubt GCs can hit Notes lowest setting...
as said before, you can get custom spring rates from GC... so u can always get softer rates if you want it dropped more...
for example: (using standard curb weight and weight ratio)
as of right now i have 375lb/in front, the softest spring they offer in 6" height is 300lbs/in... this will drop it about 0.5" more then i can go...
175lb/in rear, softest they offer in 8" is 150lbs/in... which will drop it a little less then 0.5" then i can go
Old May 22, 2009 | 02:43 PM
thanks for the info, but not sure about your spring rates, i believe the GE8 is supposed to have a higher rate in the rear than the front?
Those sound like aftermarket GD rates.
Old May 22, 2009 | 03:15 PM
dela's Avatar
nah.. i might be wrong.. but i believe they reduced the rear rates in the GEs... for more comfort... hence why they added the rear sway.. improves handling without having to sacrifice comfort
most aftermarket companies (2/3 companies) make GE springs have stiffer rates up front... there's a GD spring comparison somewhere on the board that shows stiffer rates in the rear for most of the springs...
https://www.fitfreak.net/forums/223264-post39.html
as for GE rates...
rhdjapan shows
RSR downs as 2.4kg/mm front, 2.32kg/mm rear
typeoneracing.com shows
T1R S-coil as 2.9kg/mm front, 2.5kg/mm rear
tanabe is the only company (that i know of) that has higher rear rates in both their df and nf...
*edit*
imagine the extreme, a WAY stiffer spring rate in the rear, because the weight of the car hasnt changed, the spring would compress less... so you'd have to go shorter... but if you go TOO short/stiff, it'll be like just having a short metal tube instead of a spring.. and a bump can make the spring lift up from the bottom perch, which can be dangerous if it falls out of the position... you probably can do this with a stiff damper... but as of now there are none really available for the GEs...
so you want a long spring with a soft spring rate in the rear to keep it compressed and keep the ends in their perches...
sorry for the novel
Old May 22, 2009 | 03:40 PM
most aftermarket GE springs have stiffer rates up front... there's a GD spring comparison somewhere on the board that shows stiffer rates in the rear for most of the springs...
as for GE rates...
rhdjapan shows
Cool, are your rates comfortable? I want something that improves handling but still retains somewhat decent ride quality like my DF's but I want a setup where the gap all around is max 1/2" with a bit of rake to it. I hate how the Tanabes make the car sit perfectly level and the front gap is horrendous.
Old May 22, 2009 | 03:41 PM
nice ninja edit
and oh yeah i would like those hub center to fender measurements, hell a pic would be nice if you have one.
might be in your sig, but i disable those. Cant stand em
Old May 22, 2009 | 09:16 PM
dela's Avatar
might as well be a good time if any... tell you what... i'm gonna drop it as low as it can go and give u the measurements... and if i can find my digital camera i'll take pics...
i've been kinda wondering how low it can go as well... but i like knowing im high enough not to scrape things while i drive... so its not totally dropped
i'll get back to you when i do this... maybe tomorrow
and, just fyi, the tires on my wheels are too small (205/50R15).. so i will eventually get a higher profile tire (stock diameter size would be 205/65R15)... but as of now... the tread is still useable so gonna wait till tires wear out...
Old May 22, 2009 | 09:21 PM
dela's Avatar
oh and the rates are OK... I do feel that they are a bit oversprung... really feel it in the rebound...
