General For Sale Section Sell all your General, non Fit related items here. MUST HAVE 20 POSTS
FS: A Whole Bucketful of Stuff
Old Jun 25, 2009 | 01:47 AM
Sid 6.7's Avatar
Why so serious?
Ok guys I have a bunch of stuff for sale right now. Some of it I have posted before, but I am going to condense everything down to this one thread.
First up I have a set of Wilwood brake pads:
Wilwood Q Compound Racing Brake Pads ** New in Box **:eBay Motors (item 280348814067 end time Jul-21-09 00:44:59 PDT)
This is a complete set of disk brake pads from Wilwood. These pads are made for, and will only fit Wilwood calipers
$95 shipped
These pads will fit the following calipers from Wilwood:
Billet Narrow Superlite 4
Billet Narrow Superlite 4-Race
Billet Narrow Superlite 6 Lug Mount
Billet Narrow Superlite 6 Radial Mount
Forged Narrow Superlite
These pads will NOT fit OEM calipers of any model vehicle.
They only fit Wilwood Billet Narrow Superlite 4 and 6 Piston calipers.
In the box you will find a total of four (4) separate pads, two (2) pads for each caliper.
They are the 'Q' race compound from Wilwood. They are perfect for street use and some track use. They are the most aggressive pad that Wilwood produces that have the least amount of noise and dust.
So if you want a super aggressive bite to your brakes, but you don't want them to be as loud as other race pads, and you don't want to have a massive dust build-up on your beautiful wheels, then this pad compound is for you!
These pads are brand new in the box and have never been installed, used, or even mounted into a set of calipers.
Bid with confidence. Although I am providing no warranty expressed or implied, there is a seven (7) day money back satisfaction guarantee on these pads, minus any shipping costs. You can return them for a refund, minus shipping costs, for any reason within seven 7 days of receipt, granted that they have not been installed or used, and are returned in the exact same condition that they were received in.
Here is a link to the specs on these brake pads: Wilwood Brake Specs
PolyMatrix "Q":
Characteristics & Applications
*Enhanced friction ceramic formula features the lowest noise and dust properties available from a performance compound pad.
*Improved friction over OE replacement pad compounds with smooth engagement, long service life, increased fade resistance, and quick recovery time.
*Best compound for specialized application aluminum rotors, and compatible with all vented iron rotors.
*Sprint cars with aluminum rotors.
*Disc brake conversions on street rods, muscle cars, custom show cars, and all moderate performance applications where low noise and dust are important.
Performance Characteristics
* Medium friction, smooth engagement, low abrasion on iron rotors.
* Flat torque curve. Can be used with aluminum rotors on Sprint Car applications.
* Low wear rate at low to medium temperatures
When choosing a pad compound, keep this information in mind:
Temperature range and overall friction value are the primary considerations for pad selection. The pads must be capable of maintaining the proper amount of friction for stopping power within the temperatures that will be realized on the track during the event. Then, overall wear rate must be considered. For most asphalt and road race applications, compounds in the high temperature ranges over 1000°F range are usually necessary. Dirt track, drag race, and street performance applications usually operate at temperatures between 500° and 1000°F. Keep in mind that these are general ranges, and not absolute values. Many factors and unforeseen influences can affect brake temperatures. The best indicator for pad selection will always be on track performance. If pad fade (friction loss) due to overheating occurs, then improved cooling, a heavier rotor, or a higher temperature range pad may all become necessary.
This is what the caliper looks like:(Please note, these calipers are not part of this auction, only the racing pads are being sold here. This photo is merely for illustrative purposes.)
Here are the photos of the actual pads you will receive:
Then I have a few watches:
Well, I have a couple more watches I have for sale. Both are brand spanking new, have no scratches or defects at all and come inside gift-type boxes. The first watch comes in a black cardboard box, and the second one comes in a metal box with a clear top window.
The first watch up for sale is a skeleton-type watch, gold in color, with a brown leather band. It is a manual winding watch, and as such has no battery. It is not a quartz movement. I don't know how many jewels it is, in fact I don't really know a lot about it. It's a very attractive watch and you can see the inner workings and moving parts. The hands are bright blue and have a brilliant contrast to the gold and brass colored inner parts. The second hand moves very smoothly, with almost no actual "ticking". Not quite Rolex smooth of course, but smoother than what I was expecting.
$55 shipped.
The second watch is made by Ohsen. It is a very unusual combination of digital and analog. It has analog hands with digital face.numbers on one side and two digital windows on the right side showing the time and date. It also has a stopwatch feature and a built in alarm clock. As you can see in the photos the numbers on the analog dial alternate from showing all 12 positions, to only the four cardinal positions, to blank. It also lights up in a very unusual way that is hard to describe. It is a very large watch with a wide thick rubber strap. It comes with a metal gift box and an extra set of batteries.
$55 shipped.
Then a couple of large bore analogs. these I am selling for $15/each. I have a total of 8 of these.
Then there's a Magellan GPS unit I have:
I have a Magellan RoadMate 6000T GPS system for sale. It's in real good condition with just a couple of scratches on the outside case. The screen is in perfect shape. It has been updated with the latest firmware from Magellan.
This unit will play MP3s, display photos, and has built in Bluetooth for handsfree phone usage. It uses a standard SD card for file transfer, and has a USB connector to hook up to your computer. It has 6 million points of interest in memory, has 3D bird's-eye view, and has two voices for verbal route commands.
It includes the windshield mount and 12v car adapter.
$125 firm plus shipping
It just has a few faint scratches from normal usage on the case. As stated, no scratches on the screen. It is still for sale from some websites for anywhere from $350-450.
Amazon.com: Magellan RoadMate 6000T Portable GPS Navigator: Electronics
Reference photo:
Actual unit: (notice the few small scratches/screen is clear)
Then I have a couple of cellphones for sale:
Here is a Motorola RAZR V3 that I got 2 years ago for T-Mobile. Works great, and only has a small scuff on the screen and a few small scratches on the edges from normal usage. I have a belt clip/holster, home charger, car charger, original manuals and original box. (Box, manuals & car charger not shown in photos) Works great and has no dead pixels. Has Bluetooth, audio/MP3 & video playback and a speakerphone.
It's locked to T-Mobile right now, but I can unlock it if you need, before you get it.
$100 firm plus shipping
Check phone specs here: Motorola Razr V3 (AT&T) Cell Phone reviews - CNET Reviews
Here is a brand new in the box Samsung Gravity cellphone. The phone is perfect and includes all OEM manuals, home charger, and box. I am including a 2GB microSD memory card with the phone for free. It did not come with an extra memory card at all. But I am throwing one in for free as well as a Pearl Pink Hard Case.
The phone is so new it still has the protective plastic film still covering the back of the phone.
I got this phone for my wife, but she changed her mind and wants a Blackberry.
The Gravity is great for texting with it's slide-out Qwerty keyboard. It also has stereo Bluetooth, a speakerphone, photo caller ID, an MP3 player and a 1.3 MP built-in camera/video with flash. It is also has the myFaves feature. It is locked with T-Mobile for now, but I can unlock it if you need before you get it.
$150 firm plus shipping
Specs: Samsung Gravity SGH-T459 - Lime (T-Mobile) Cell Phone reviews - CNET Reviews
And then I have several SD, SDHC, miniSD, microSD, and microSDHC cards for sale.
I have several Sandisk 8GB MicroSDHC memory cards. They come with both a full-size SD adapter and a USB adapter.
$25 each firm (shipping extra)
I also have the following: The cards marked "16GB" are actually 2GB cards. The company I got them for said they were "misprinted". (shipping extra)
  • (1)Transcend 8GB SDHC card --- $20
  • (1)Transcend 4GB SD card --- $12
  • (1)Kingston 4GB MiniSD card --- $8
  • (2)Sandisk 2GB microSD cards(labeled "16GB") --- $10/each
  • (2)PNY 2GB SD card --- $7/each
  • (1)Sandisk 1GB MiniSD card --- $6
Old Jun 27, 2009 | 11:03 AM
Fit4Trav's Avatar
oh I like the OHSEN Watch
Old Jun 27, 2009 | 11:51 PM
FLFIT239's Avatar
you were serious when you said a bucketful of stuff
civilcivil
Site Feedback and Suggestions
Jun 16, 2010 01:06 PM
Sid 6.7
May 28, 2009 01:08 AM
