Best shop to get oem oil filters at.
Did a search and didn't find anything.
Is Bernardi the best/cheapest online store to get a six pack of oem oil filters at?
I know Walmart'a Super tech are cheaper, but I just want to use OEM till my warrenty is up.
Thanks
Thanks
Don't sweat the OEM filter. There are better choices out there for the same money, such as PureONE, Wix/NAPA Gold, Carquest Blue. All of those are constructed using metal instead of cardboard like the OEM filter made by Fram, and will withstand an extended drain well.
I'm not sure how much bernardi sell them for, but www.handaaccessories.com sells them as well for pretty cheap.
Plus it's cheap and usually comes with the crush washer so I don't have to reuse the old one or go find one that fits.
College Hills Honda has the Filtech OEM filters. Much better than the Honeywell (Fram) OEM filters. That's what I use and where I get them.
Me too. If I have an engine failure, they can't blame it on the oil filter. In the unlikely event of an engine failure, I would rather not have to fight it out with lawyers to get it fixed. Filtech OEM filters are just fine for me and I can afford them. After my extended warranty runs out I will probably use Purolator filters.
Here's a deal for you!
Purolator PL14610 PureONE Oil Filter (Pack of 2) for $9.48
Rebate for the two 4.00
Total (Pack of 2) $5.48
Free shipping if you spend $25.00
You can find alot of auto stuff.
Amazon.com: Purolator PL14610 PureONE Oil Filter (Pack of 2): Automotive
Rebate;
http://g-ecx.images-amazon.com/image...223689362_.pdf
Rebate;
Hyundai's 100k warranty requires you to use an OEM filter, and document your changes.
The only way the manufacturer can require you to use an OEM filter is if they give it to you for free. Otherwise it might be highly recommended but you're free to use whatever you want as long as it is equivalent to OEM.
You have to document your changes, but as long as you are using the correct grade of oil and the correct filter at the correct change interval, it meets warranty requirements.
And any manufacturer requires you to document your changes.
There is some truth to why Hyundai recommends OEM filters. Back in the late 90's Fram spec'd their Honda filter with a higher bypass PSI for a Hyundai engine because the threads were the same. Some folks grenaded engines when the filter starved the engine of oil, and a lot more people complained about excessive engine noise. Fram actually did not have a filter for Hyundais on the market for a few years. Ever since then Hyundai has been cautious about non OEM filters, and Fram in particular.
Another reason why Fram is the orange can of doom.
I guess they must have sold them out. I ordered mine few weeks ago and got them within a week. Amazon is always conservative on wait time.
