handling of sport vs. base?
Old May 1, 2006 | 11:13 AM
dartvader's Avatar
anybody drive both to any great extent? you would think the wider tires on the sport would make a big difference but you never know.
Old May 1, 2006 | 11:41 AM
Mesaba's Avatar
I didn't notice any difference, I just wanted to be able to plug in my mp3 player.
Old May 1, 2006 | 02:20 PM
wyy183's Avatar
I've driven both, back to back.
The sport does better because it has more agressive rubber, not much, but a bit better. Aside from that, they are the same.
Old May 1, 2006 | 02:53 PM
Jonniedee's Avatar
Most important to note :
You'll also look COOLER driving the Sport
Old May 1, 2006 | 04:02 PM
Toeside's Avatar
Any noticable difference in handling would most likely come from the tires. Nothing affects handling more. The standard 15" Sport tire is wider by 20mm (195mm vs. 175mm) with a lower profile, thus providing a larger contact patch, more grip, and more repsonsive handling.
http://www.tirerack.com/tires/tirete....jsp?techid=10
The 15" wheels are probably heavier, which is a negative. Unsprung weight is generally considered "bad". Read this if you're really care:
http://en.wikipedia.org/wiki/Unsprung_weight
The groovy spoiler on the Sport might make a difference if you're driving really, really fast... but I doubt it's a functional design. As for the extra 40 lbs of curb weight... well that could be offset by leaving Fido at home, or going on South Beach for a few weeks.
Nothing I read about Fit specs indicates there are any other differences in, say, the suspension that could affect handling between the two trim levels.
Old May 2, 2006 | 02:43 AM
Paulo107's Avatar
the sport handles a little better...i think
Old May 2, 2006 | 03:44 AM
kkim's Avatar
I think it all boils down to the wider tires/wheels on the sport, if it indeed does handle any better. That said, I'll be throwing some 15x7 lightweight wheels with 205/50-15 ultra high performance summer tires on my base 5 speed fit... we'll see which handles better at that point.
Wanderer.
Feb 9, 2015 05:27 PM
mxl180
Dec 25, 2014 10:17 AM
Pucci
Mar 24, 2014 10:52 AM
fit451
Oct 27, 2008 10:24 AM
Atlas2k7
Nov 19, 2007 10:57 PM
