HID's re-installed.
Old May 5, 2006 | 07:45 PM
Tomh's Avatar
Senior Member
HID's re-installed.
i used the kit i had from my civic, but i changed out to a stock OEM phillips D2S bulb, instead of the custom 9006 bulbs, so no more 6000k for now.
Before re-install.
and after teh re-install.
i need to get some night pics, but this is just as of right now, i'm still waiting on teh proper adapter rings to better seat teh bulbs and to actually get a clean cut, but this is as of right now, i had to adjust the headlights aiming though last night since th eright side was pointing into teh night sky, lol.
Old May 5, 2006 | 07:46 PM
corey415's Avatar
Nice. Hope it doesnt glare too much.
Old May 5, 2006 | 07:50 PM
Tomh's Avatar
Senior Member
no more the what a IS300 does, since they have the same housing type, though they are designed to have a real cut, which is why i'm stillwaiting on the adapter rings, so once i get those i shoudl be okay, but atleast i haven't gotten flashed yet, lol.
Old May 5, 2006 | 08:26 PM
corey415's Avatar
If you take any wall cutoff shots, dont forget to post it here.
Thanks!
Old May 5, 2006 | 10:11 PM
fshwcrs's Avatar
Not all reflector type housings are the same...
Old May 5, 2006 | 10:51 PM
Tomh's Avatar
Senior Member
Thanks!
once i get teh Adapter rings i will, as of right now it won't be pretty i'm sure.
Old May 6, 2006 | 07:30 PM
dougiepants's Avatar
Avid FitFreak Poster
Look great. I can't wait till I install mine
Old May 6, 2006 | 09:52 PM
Tomh's Avatar
Senior Member
i finally got them adjusted just right, so the beam itself (not including any glare that there may be) won't blind on-coming traffic. (hopefully).
Old May 6, 2006 | 10:05 PM
FitDaddy's Avatar
have you thought about putting them in your foglights. I have some HID's i thought about buying the 3k yellow bulbs and put them in the fog's.
Old May 6, 2006 | 10:39 PM
Tomh's Avatar
Senior Member
Very much so, just not yet, but eventually, i've seen them before on a 96-00 civic hatch, they were purple , but still looked pretty hot.
Old May 7, 2006 | 05:36 PM
fitjunkie's Avatar
what kind of kit did you use? i heard adapter ring doesn't give you the proper cut-off...but NIGHT PICS PLEASE!!! your ride is HOT...
Old May 8, 2006 | 07:03 PM
LB3DR's Avatar
I plan on retro fitting them with hid projectors in a couple of months and tent my fogs lights in yellow and yellow hid bulbs or regular.
Old May 8, 2006 | 09:12 PM
Tomh's Avatar
Senior Member
but theey'll atleast give a better cut then what it currently looks like, it'll never be perfect without a true conversion involving the projectors outta a car that comes with HID's stock, and the Kit i used is outta a lexus, what year or model i have no clue, they came from a body shop, atleast that's what i was told by the radio shop that got them for me.
