Maintenance Check
Old Nov 9, 2009 | 04:56 PM
chinkyy's Avatar
Maintenance Check
how much you guys pay for your B1 maintenance check? this is for those who bring it to honda.
Old Nov 9, 2009 | 10:51 PM
randay's Avatar
which one is b1? is that the rotate tires one? i would just do it yourself man, dont trust those service department guys!
Old Nov 9, 2009 | 11:18 PM
HONDAMATIC's Avatar
rotate and oil change
Old Nov 10, 2009 | 02:17 AM
chinkyy's Avatar
ya those guys look fukcing shady. i thought i would only pay for oil change but labor for everything came out to be like 114.....
Old Nov 10, 2009 | 03:26 AM
HONDAMATIC's Avatar
well they went over it with you, if you dont like it then leave.. all the dealers cost almost same, retail oil change is like 50$, then disposal, then about $60 for tire rotation and the inspection.. can go firestone instead or something. the fit is the EASIEST oil change EVER too.. just do it yourself, i just did mine in the rain at night
Old Nov 10, 2009 | 03:36 AM
HONDAMATIC's Avatar
by the way the honda oil filter is 7-9$ already
Old Nov 10, 2009 | 11:37 AM
holokai's Avatar
look in your owners manual and there's the description for all of the service codes. oil change and rotating tires are easy enough for anyone; if i can do it anyone can. you might as well change to synthetic oil if not already done (royal purple), and get a magnetic drain plug or a fumoto valve =P
and seriously, i wouldn't bitch about the price if you're taking it to the dealer. their labor rate won't change if it's changing oil or troubleshooting an ecu issue. you're paying the minimum amount it takes them to cover their overhead; they're not some friendly mechanic you can bribe with a plate lunch and soda. . . . . if you're concerned about warranty but want to save money then make sure you follow the maintenance schedule, write down everything you do, and keep your receipts.
Old Nov 10, 2009 | 12:06 PM
randay's Avatar
bring me some kj's ill rotate your tires for you :P
Old Nov 10, 2009 | 07:29 PM
HONDAMATIC's Avatar
line up the valve stem on the hupcaps or no soda for you
Old Nov 11, 2009 | 06:40 AM
chinkyy's Avatar
this is the first car i've OWNED so i am not familiar with how much dealers charge, labor rate, etc. now i know so ok.
Old Nov 11, 2009 | 10:24 AM
holokai's Avatar
do yourself a favor and read through the entire owner's manual. it'll give you a good idea of what you can or can't do. also refer to the DIY forum on this site for more information on any topics the owner's manual doesn't have. getting a service manual might be another good idea as it'll have way better instructions/details than the owner's manual. just make sure that no matter what DIY projects you undertake, you do so safely and with an honest assessment of your wrench turning capability. learn how to do basic maintenance (oil change, filter change, rotate tires) before moving on to mods. gotta learn to walk before you run.
Old Nov 11, 2009 | 04:13 PM
chinkyy's Avatar
thanks for caring about me buddy. i'll mod what i want when i want. and i knew what they were gonna do. now i know the labor rate is a bitch and i'll look into doing stuff myself.
Old Nov 11, 2009 | 04:36 PM
HONDAMATIC's Avatar
every car i buy i read the manual first, youll be surprised what you learned and what the saleman doesnt tell you
service rate for about EVERY dealer is about 100$hr and up.. and no, the mechanic doesnt even make near half that, thats why i drive a fit and not a TL type S
Old Nov 11, 2009 | 05:58 PM
randay's Avatar
the rate is normal, its about convenience. if you dont have the time, then its worth it.
personally i'd rather do it myself because i want to know whats going on with my car and i want it done right. other people wont care about your car, its just a job to them.
Old Nov 11, 2009 | 08:36 PM
holokai's Avatar
true. you might even piss them off if you come in complaining about some BS symptom that is completely your fault and could be fixed by reading the manual.
all things considered, the main point in all of this would be to do your research before opening your mouth, be humble about what you know, ask intelligent questions (people will respond intelligently), and listen to what people have to say. in even simpler terms, just don't be a jackass and you'll find more help than hate.
Old Nov 11, 2009 | 08:38 PM
holokai's Avatar
Originally Posted by HONDAMATIC
...thats why i drive a fit and not a TL type S
no lie, you'd drive the Fit anyway. . . it might have a k20 or high boost & IC but still a Fit
too bad you didn't work today, was super chill.
Old Nov 11, 2009 | 08:47 PM
HONDAMATIC's Avatar
the storm never come to work huh? maybe itll come in tomorrow
Old Nov 11, 2009 | 08:49 PM
HONDAMATIC's Avatar
oooh i HATE when that happens.. those people are why i quit my job
Old Nov 11, 2009 | 10:04 PM
randay's Avatar
yeah i hate that too, but comes with any customer service job
just gotta treat em nice and tune em out, then just fix it.
Old Nov 12, 2009 | 12:28 AM
holokai's Avatar
hopefully not. better tie down your car cover if it does though. . . buggah looked like was lifting up on Tuesday.
