sportmax 502+ Eibach sportline ?
Old Nov 11, 2009 | 03:47 PM
honda_82's Avatar
So I was looking to the sportmax 502 to put on my GD3. I was looking for the 15x8 +15. I know that someone fit some 16'' on his red GD3.
But I was wondering, I'm on Eibach sportline and I dont plan to go with coilovers, so with a 195/50/15 tire on this, would this be a good setup or it would be shit?
I've search alot but I just find dude with mad camber and slammed as hell... And I dont know anyone around my town that have these wheels just to make a test fit...
Old Nov 11, 2009 | 04:12 PM
B1str0's Avatar
RubberBabyBuggyBumpers
+15 and 15x8 on sportlines would def rub you will need to roll/pull the fenders and add some camber u can use camber bolts for the fronts and shims for the rear hubs or contact fit4trav and he can point you in the direction of a full camber kit..
Old Nov 12, 2009 | 10:24 AM
honda_82's Avatar
I know this setup will rub. But if I roll the fenders and add a little camber on the front and rear, I think it should fit properly...? I'm not as low as some others with low offset, so I don't have to put a shitload of camber to fit the wheels under the fender I think?
Old Nov 12, 2009 | 04:24 PM
B1str0's Avatar
now that you mention it think member rvall004 had that same sportmax setup but i dont remember how much camber he was running. that and he was on coilovers when he did it pm him and he shall have all the answers you need
Old Nov 12, 2009 | 08:32 PM
rvall004's Avatar
i did have the same set up....I rolled and pull my fenders....to make them fit nice in the front i suggest -2.5 camber with the camber bolts...in the back i have to do the washer trick and it gave me 4.7 neg camber...the only problem with the back is that the toes gets all fucked up and tires will not last you as long s as they should if the toe is right....but anyways is a very nice set up on the less expensive side ....you can look around there is a bunch of pictures that i have with the set up....good luck
soobieajax325
Jul 3, 2017 10:02 PM
BlueBoogers
Apr 20, 2012 10:42 PM
honda_82
Dec 10, 2011 08:55 AM
GD3_Wagoon
May 25, 2010 12:11 AM
gthumb23
Tanabe Racing Development USA
Oct 23, 2006 12:18 PM
