Kwsc: pro/cons for running a BOV vs a DV?
Old Nov 12, 2009 | 10:38 PM
dewthedew's Avatar
Im going to upgrade the DV the kit comes with to either a metal forge DV or look into getting a BOV. Is there any pro/cons of running one or the other?
These are the ones im looking at:
Forge BOV http://www.ecstuning.com/Volkswagen-...BOV/ES1832068/
Forge splitter DV/BOV http://www.ecstuning.com/Volkswagen-...ke/BOV/ES8288/
Forge DV http://www.ecstuning.com/Volkswagen-...lve/ES1832054/
Old Nov 14, 2009 | 01:45 PM
dewthedew's Avatar
I think Im going to go with the BOV to get rid of that huge hose.
Old Nov 14, 2009 | 03:50 PM
MNfit's Avatar
What would I need to do to switch it to a BOV, and whats a DV?
Old Nov 14, 2009 | 04:19 PM
Evotech8's Avatar
BOV= Blow Off Valve
DV=Divertor Valve
Both serve the same function, but a divertor valve recirculates the released air back into the intake. The benefit of a DV on MAF (mass air flow) equipped car is to keep the AFR and idle stable since its metered air going into the engine. On a Fit I don't think it matters since its a non-MAF car and a BOV will work just fine and with less plumbing. And a BOV will make a loud woosh sound than a DV since air is released to open atmosphere.
Old Nov 14, 2009 | 04:22 PM
dewthedew's Avatar
the bov kits for the vw 1.8t engine works for the kwsc because it includes everything block off plug and all.
Old Nov 16, 2009 | 09:30 AM
Texas Coyote's Avatar
You don't care about getting rid of the big hose hose, as much as you do the fast and furious sound of the BOV.... I am wondering if you are thinking of an adjustable BOV that can possibly increase your boost...
Old Nov 16, 2009 | 10:06 AM
robertdjr's Avatar
i see.. that's the use of those valves.. thanks for the info..
Old Nov 16, 2009 | 10:20 AM
The BOV and DV are used to limit pressure but on turbos an adjustable BOV allows you to optimize power as well.... I don't know if one can be utilized to do that though on the Rotrex super charger used by KraftWerks.... Someone is sure to figure out how to if it hasn't been already.
Old Nov 16, 2009 | 12:35 PM
dewthedew's Avatar
the forge bov is only a wooosh noise nothing ricey.
Old Nov 16, 2009 | 01:49 PM
I was just kidding you, I know where your head is when it comes to your performance mods.
Old Nov 18, 2009 | 05:22 PM
Jesse's Avatar
waste gate controls boost not bov. bov used to be called a popoff valve by some will keep you from damaging your butterfly in tb from pressure when throttles closed. a bov diverts the pressure into the atmosphere where as a dv puts it back into circlulation but undo hose and the dv becomes a bov lol.
Old Nov 18, 2009 | 10:29 PM
I thought about that later in the evening after posting it and felt pretty goofy.... Now that someone finally noticed my goof I feel even worse...LOL.
Old Nov 19, 2009 | 01:05 AM
dewthedew's Avatar
there is no wastegate on the kw s/c only a dv
Old Nov 19, 2009 | 01:23 AM
Koi's Avatar
Koi
He was correcting Texas about what he said regarding BOV's on turbos.
Old Nov 19, 2009 | 04:37 AM
[QUOTE=Koi;777436]He was correcting Texas about what he said regarding BOV's on turbos... And rightfully corrected I must add.
Old Apr 5, 2010 | 04:57 AM
Koi's Avatar
Koi
Reviving a long dead thread:
Dewthedew, did you ever get that Forge BOV?
doctor J
Mar 30, 2016 07:47 AM
theFITMASTER
Jan 13, 2010 11:38 AM
super929
Sep 9, 2006 01:42 PM
Steve
Sep 12, 2005 09:30 AM
