What is the best gear to use at 40mph
Old May 10, 2006 | 09:28 PM
benfal2001's Avatar
What is the best gear to use at 40mph ? 4th or 5th on MT ? Does it make a big difference on fuel consumption ? Does using low gears use more gas ?
I love my fit! Already 620 miles after one week Not washed yet No ticket yet
Old May 10, 2006 | 09:37 PM
fshwcrs's Avatar
Yes, using lower gears uses more gas.
Old May 10, 2006 | 09:55 PM
aziatiklover's Avatar
Master FitFreaker
yea that^^^^^^^^^ just shift has much as i can lol
Old May 10, 2006 | 10:29 PM
kz098123's Avatar
If it's a flat, level road, use 5th gear.
Old May 10, 2006 | 11:50 PM
DRum's Avatar
Senior Member
Use 5th gear.
Old May 11, 2006 | 12:20 AM
Gordio's Avatar
if u dont' mind acceleration (i.e. in city) use highest gear possible. for me, if i know i'm crusing, i'm using 5th gear (or neutral) even if its 25mph.
lower gears use more gas cuz they require more RPMS to accomplish the same as a higher gear for a given speed.
Old May 11, 2006 | 03:08 AM
BKKJack's Avatar
Agree. Driving a manual is all about feel. Use your senses to tell you what gear is right, Grasshopper.
Just cruising down the street, with no immediate need to accelerate: Put it in the highest gear that doesn't cause the thing to buck. Rushing up that mountain 2 lane with limited, short passing zones and lot's of motorhomes and harley trains: Keep it up in the powerband.
Old May 11, 2006 | 07:45 AM
Karvin Karl's Avatar
I like to keep mine (MT) between 3200 - 4000 rpm. Granted my turf is urban, but it allows good engine braking-effect and remains in the sweet spot for rapid deployment!
Old May 11, 2006 | 08:00 AM
Popeye's Avatar
1st gear........oops sorry wrong car
Old May 11, 2006 | 11:25 AM
dougiepants's Avatar
Avid FitFreak Poster
I use 4th gear
Old May 11, 2006 | 02:41 PM
Dañiel's Avatar
Ok, that's 64km/h. If I'm holding that speed 5th for sure. If I anticipate that I'll need to step on it, then 4th it is......or 3rd. 5th gear is good down to 55km/h AKA 33mph if you don't need much power.
Old May 11, 2006 | 05:21 PM
kentris's Avatar
40mph I drive in 5th gear.
Anything below 35mph and I'll use 4th gear as the car has a bit of a struggle trying to accelerate in 5th gear at 30mph.
Old May 11, 2006 | 06:55 PM
benfal2001's Avatar
Ok and I suppose it drinks more gas if I use compression over brakes ? I did it a lot on my two civic for 4 years each one and the brakes were as new after 130 000km.
Stoli124
Aug 1, 2023 06:33 AM
wilcoholic
Jul 30, 2010 09:27 PM
AppleMac*Fit
Dec 27, 2008 10:10 AM
tonyd3773
Jun 21, 2008 02:51 PM
tonyd3773
Jun 20, 2008 04:33 PM
