searched and searched: 16x7 +40 ?
Old Dec 2, 2009 | 02:01 PM
thebluepotato's Avatar
Is anyone running a 16x7.0 with a +40mm offset?
If so, are you running a 50 or 45 series tire and are you lowered at all?
I'll keep checking, but nothing much out there in terms of this fitment on a 09 Sport.
Thanks in advance!
Old Dec 2, 2009 | 03:29 PM
redrumm's Avatar
just run the stock sport tires. you should be fine.
are you lowered or stock?
Old Dec 4, 2009 | 11:13 PM
I am not anything at the moment, but would like to go with a set of 16x7 rotas that are +40 on the offset and not sure they will fit on a lowered Fit. Anyone?
Old Apr 5, 2010 | 06:09 PM
j6kwok's Avatar
BUMP
would like to know as well
I'm lowered on Eibach Pro kit and I'm looking at Buddy Club but they only make 16x7 +40 4x100 bolt pattern
Old Apr 5, 2010 | 06:29 PM
JDMxGE8's Avatar
The ideal tire size for 16x7 would be 205/50/16.
Old Apr 5, 2010 | 06:37 PM
j6kwok's Avatar
Thanks for the reply but will it rub running a +40 offset with 205/50/16 or 205/45/16
Old Apr 5, 2010 | 06:57 PM
k20a298ek's Avatar
get rid of the wheels you will rub like crazy. +43 at least.
Old Apr 5, 2010 | 07:01 PM
JDMchris.com's Avatar
I run THIS
you will be fine. I run 16x7 on a 205/45/16. you can run a 205/50 if ir stock height other wise i would go with the 45.
Old Apr 5, 2010 | 07:07 PM
Octrain's Avatar
What's your offset and are you dropped at all? Does it rub at all if you hit a bump? Was looking at the same wheel/tire setup with +43 offset (RPF1's) and 1.2"F 1.0"R drop (Progress springs). Sound pretty solid?
Old Apr 5, 2010 | 07:09 PM
I run THIS
+42 offset no rubbing on bumps, yes I am dropped about 1.8 up front and 1.5 in the rear. Only rubbing comes from extremely hard cornering. You should be fine on that setup ur wanting to run.
Old Apr 5, 2010 | 07:14 PM
j6kwok's Avatar
I want these Buddy Clubs but they're +40
D-UNIT09 is running Enkeis +40 on 205/45/16 and he's lowered on DF210s with no problem was wondering if this is a special case or what
Old Apr 5, 2010 | 07:20 PM
keepitpg's Avatar
i love college
i have a gd and im on 16x7 +40 on 205/45/16's and slammed. i rub on bumps and turns
Old Apr 5, 2010 | 07:35 PM
Octrain's Avatar
Is this the GD in your sig? Mine's a GE; apparently there's a big difference with offsets and drop potential
Old Apr 5, 2010 | 07:48 PM
I run THIS
the Buddy club sf P1? I ran those in 16x7 with +42 offset in that tire size as well with no problems.
Buddy club doesnt make a 16in wheel with a +40 offset
Old Apr 5, 2010 | 08:03 PM
Type 100's Avatar
Tire sizes will be slightly different depending on the chassis.
GD: 205/45R16
GE: 205/50R16
On my GD1, I have 16x7 +45 wheels at stock height and I use 205/45 tires. No rubbing whatsoever.
GEs are okay with the same tread width but the aspect ratio should be a little bigger.
Old Apr 5, 2010 | 09:50 PM
j6kwok's Avatar
that's what I thought too but apparently BC stopped making the +42 in 4x100 their website is wrong my local shop called and confirmed this
Old Apr 5, 2010 | 10:35 PM
Wongawa's Avatar
I have 16x7 +42 and I just changed rims and used the stock tires for now. I'm not lowered yet though.
Old Apr 5, 2010 | 10:37 PM
I run THIS
hmmm... the 2mm wont make a difference anyway.
Old Apr 5, 2010 | 11:43 PM
Sugarphreak's Avatar
Push My Button
2mm always makes a difference
I know this is a GE8 thread, but I had +42 rims on my car and massive rubbing problems... I went to +45 and it all went away!
Also here is a link the the lightweight wheel thread, it details all the rims that come in high offsets and are lighter than the OEM rims:
https://www.fitfreak.net/forums/fit-...el-thread.html
Chris, could you sticky that thread for me. It is a valuable database for anybody looking for rims with high offsets.
Old Apr 5, 2010 | 11:46 PM
I run THIS
werent you on 17s? the +40 on 16s are fine.. I had 16's in +38's with no rubbing.
