ADDING DRLs in US NEED CANADIAN HELP!
Old May 12, 2006 | 04:57 PM
sLiVeRwOrM's Avatar
Four Wheels Enthusiast
hey guys, so I just took a look at the fuse box in the US model and there is a place for DRLs but its got no fuse.. iam thinking if you put the correct amperage fuse in place it will work? so I know the canadian's have DRLs and so I would like to ask one of them to please take a look in the fuse box and tell me what amp the fuse is so then I can find one and put it in there and see what happens... nothing bad an happen and if it does iam under warranty!
Old May 12, 2006 | 05:00 PM
李克勤's Avatar
look at the owner manual, it will tell you
Old May 12, 2006 | 05:14 PM
sLiVeRwOrM's Avatar
the only thing i found in here is in the fuse location which reads..
No. Amps. Circuits Protected.
8 7.5A DRL*2
18 (10A) DRL*2
*2 canadian models
Old May 13, 2006 | 09:53 AM
dgff's Avatar
In the Canadian Honda vehicles that I have seen, the DRL system consists of a small control box housing some electronics and relays. And a couple of fuses in the fuse box that route power to the box.
In my 90 Civic and my 97 Prelude, the box is located behind the dash. I presume they use the same setup in newer Hondas. On the US Hondas, I believe the wiring harness is in place but ends with a open connector where the DRL box on Canadian cars plug into.
So my guess is that you would need both the DRL unit as well as a couple of fuses.
Old May 13, 2006 | 11:02 AM
sLiVeRwOrM's Avatar
augh, to much work i think i will just turn on my lights when i drive around lol
LarryS
Jun 24, 2016 03:29 PM
SilverEX15
Jul 30, 2015 03:30 PM
Neil-in-Arizona
Jul 25, 2009 02:01 AM
TWGE08
Jun 10, 2009 07:54 PM
FitLIKEaGlove
Feb 17, 2007 11:52 AM
