WTB: Front and rear camber full kit
Old Dec 22, 2009 | 04:49 PM
OutkastGS3's Avatar
I don't know if there's such a thing for the front,
But I am trying to achieve as much negative camber as possible.
I know there are kits out there for the Fit and if anyone is looking to sell/ or know where to get it fast. that would be great!
Also, if anyone can further explain the shim/washer tricks for the camber, that would be awsome too!!
PM me!!! Thank you.!
Old Dec 22, 2009 | 08:31 PM
accordguyintake's Avatar
the front you can get camber bolts, the rear needs washers but honestly i dont know really how it works, you just stick em in between the drum and hub or something... if you go that route it'd prolly be best to use a precise measuring instrument, make sure all washers are the same size!
Old Dec 22, 2009 | 09:18 PM
OutkastGS3's Avatar
I have the camber bolts for the front, but it only allows a 1.75 degree more .. If you ever come across any info about the washers DIY thingy.. let me know!! Thanks!!!
Old Dec 23, 2009 | 11:51 PM
SPON FIT's Avatar
i run 2.5 degrees of camber in the front with 2 sets of camber bolts and could run more if i wanted
Old Dec 23, 2009 | 11:56 PM
OutkastGS3's Avatar
So, running camber bolts on top hole and bottom hole on the strut?
Old Dec 24, 2009 | 10:26 AM
SPON FIT's Avatar
yes sir
Old Dec 25, 2009 | 06:24 AM
OutkastGS3's Avatar
yes sir
Interesting.. I am going to try that .. Thanks man!
Old Dec 25, 2009 | 07:26 AM
SPON FIT's Avatar
kyobi
Jan 30, 2012 08:50 PM
Lil Blue
24
Jan 11, 2011 11:17 PM
illest.GD3.JB.squad
Aug 7, 2010 05:04 PM
chinkyy
Hawaii Community
Oct 17, 2009 01:44 PM
BoriJDMGD3
Feb 16, 2009 11:27 PM
