Looking for yellow film that wont burn
Old Dec 31, 2009 | 02:38 AM
qbmurderer13's Avatar
I purchased the yellow fog light film from koolkev. Thought it would be ok to run them with Nokya 2500k bulbs per someones advice on here. They are now brown after about 2 months. How do I remove them? Also is there any film that wont burn, or at least lasts longer?
Old Dec 31, 2009 | 09:49 AM
FitVic's Avatar
um i just used a blade and scratched it off. Other than that i guess turn it on for a little to heat it up then try to peel it. Its only because the bulbs are hotter than the HID's from what i can tell. I had the same problem after 6 months with mines then i decided to use HID foglights 35watt and its been fine for a long time now.
Old Dec 31, 2009 | 10:16 AM
onemiglandicho's Avatar
I agree with using a blade but I wouldn't scrape it off. If it was me, I'd remove the fog light housing then use the blade to peel a small amount of vinyl at the edge then just use your fingers from then on. It'll be a bit of a PITA but at least you're not going to scratch your lens. Try using a heat gun or just the regular blow dryer to soften up the film.
Try azncarbos's yellow vinyl film. He sells it for $7.50 and if my memory is correct, he said that he has been using it for 2 years.
Old Feb 18, 2010 | 11:09 AM
vtecfit1's Avatar
IM USING A.M. YELLOW BULBS (35WATT) AND LAMIN-X
BUT I LEAVE A SMALL AMOUNT OF THE EDGE OF THE GLASS UNCOVERED (1/8") AND IT SEEMS TO LAST 6MO OR MORE, I USUALLY CHANGE IT OUT BEFORE IT GETS TOO SCRATCHED UP FROM ROAD DEBRI (SP)
I READ SOMEWHERE LEACING THE SLIGHT SPACE OF GLASS UNCOVERED HELPS THE GLASS NOT HEAT UP AS MUCH THUS BURNING THE LAMIN-X
HERE IS THE WEBSITE
Lamin-x Protective Films - Protect with Style
CAPS MEANS NOTHING
fresh fit
34
Aug 26, 2020 02:45 AM
lidoshorty02
28
Apr 5, 2013 10:41 AM
EFitREI
13
Jan 22, 2013 09:14 PM
Committobefit08
Jun 21, 2010 02:39 PM
gryhrt
Feb 16, 2010 09:50 AM
