Diy: Acura mdx map light roof console
Old Jan 23, 2010 | 08:54 PM
pbz08gd3's Avatar
well guys i had seen someone do this already w/ the cl map lights but i love my ray-bans too much lol . so i went w/ an mdx concole instead.
lets begin.
so first i took the console and made a stencil for the hole i needed to cut.
measure 10 times and cut once i always say. once i knew the fit was good i started so solder 2 wires onto the console since i didn't get a plug w/ it.
since the console wasnt the same color (it was dark grey) i bought some paint to match it up.
once it dried i put it in the roof. NOTE*** i had to use the foam bloack that came out when i cut the headliner to create some room for the sunglasses holder. no cutting or anything just pulled the headliner down a bit and stuff it in between it and the roof. its exactly 2 inches just like the compartment is deep. the console has 2 tabs on one side to hold it on so i only screwed it in by the lights. i used 2 wooden blocks and a paint mixer stick as a bracket for the screws and to keep to console from falling out. **sry no pics of that i was trying to beat the rain**
splice one wire into the red/wht wire on your dome light plug and the other to a ground. (i used the same as the dome light which is the screw hole for it).
finally put your dome light back in place amd enjoy
drop some comments and rep my way if you like
Old Jan 23, 2010 | 09:06 PM
Slimjimx701x's Avatar
Thanks for the DIY. It seems like there a little gap with the console and the ceiling, but that proproly due to the shape of the headliner.
PS. Good to see Staedtler
Old Jan 23, 2010 | 09:27 PM
billmus86's Avatar
My Lips Bigger!
clean your camera lens
good mod job
Old Jan 23, 2010 | 11:31 PM
gimme's Avatar
Master FitFreaker
nice, but what year mdx? 2004 look different. i think they are 2003
Old Jan 24, 2010 | 12:05 AM
niko3257's Avatar
FitFreak GE8 DIY Guy
you can get the accord one also. and you don't have to paint
it. i did the same thing a while back and got one from an accord.
matches the interior pretty good.
i also think the odyssey has one also.
Old Jan 24, 2010 | 12:39 AM
secondspassed's Avatar
Yes, please.
Old Jan 27, 2010 | 01:15 PM
YellowStarS2000's Avatar
Oooh, another weekend project!
Old Jan 29, 2010 | 08:24 PM
grtpumpkin's Avatar
Gimme a part number people! I just spent like an hour and a half on Bernardipatrs.com and couldn't find the f$%^er! Please and thank you!
Old Jan 29, 2010 | 11:52 PM
There are like 1,000 of these on eBay, you're gonna pay 3-6X more money buying one of them new. Honda's price is ridiculous for anything with homelink.
Old Jan 30, 2010 | 07:13 PM
grtpumpkin's Avatar
Is that the only way to get it? With Homelink I mean? I don't care about that, I just want maplights/sunglasses holder. How about the Accord one?
Old Feb 1, 2010 | 05:04 PM
pbz08gd3's Avatar
accord one works too i got mine on ebay also. you're better off going that route. im pretty sure the accord has no homelink. the cl has a similar one too not sure if it has sunglasses tho. or take a trip to your local junkyard :/
Old Feb 1, 2010 | 06:07 PM
grtpumpkin's Avatar
Got a brown one on E-bay for twenty bux shipped to me! Thanks for the tip my friend +rep to ya. Now, how hard would it be to make the Homelink functional I wonder.......
Old Feb 1, 2010 | 08:32 PM
the homelink is just a 12v power and a ground. you should be able to splice into the map light wires for that.
Old Feb 1, 2010 | 10:09 PM
AtticusFit's Avatar
i just want the map lights and the sunglass holder, any idea what accord year model will work or other console work with our fits??
Old Feb 3, 2010 | 04:43 PM
grtpumpkin's Avatar
Follow the good advice given to me, get the MDX with the Homelink. It doesn't add anything to the price and the buttons are small enough that no one will ever notice. I am going to experiment with making mine functional, just because I think a Fit with a working Homelink opener would be cool. I'll be installing mine tomorrow, along with four new speakers Woot!
Old Feb 4, 2010 | 10:59 AM
pbz08gd3's Avatar
head my words man. measure measure measure and then cut. better to cut not enough than too much lol. the homelink is super easy to do. i pulled the console back out soldered one little wire from the other pin to the + wire and wallahhhh homelink activated
Old Feb 4, 2010 | 06:47 PM
grtpumpkin's Avatar
You mean the third pin that goes to the OE wiring in the MDX right? And did you run a wire directly to ground from the console or did you splice it into the dome light wire? My console map lights aren't working and i want to make sure that I wired it the same way you did...
Old Feb 5, 2010 | 10:28 AM
pbz08gd3's Avatar
i just spliced a small piece into the + for the homelink right by the console. my ground i ran a wire back to the dome w/ the +. i put a circle bunt on the end and screwed it in w/ one of 2 screws that holds the domelight on which is the actual ground. if you dont screw it in hard enough the grund wont make contact.
Old Feb 5, 2010 | 11:43 PM
grtpumpkin's Avatar
Cool, I will try that after it stops snowing (sometime next week LOL) God I hate winter!
Old Apr 23, 2010 | 01:47 AM
chrisng's Avatar
gonna try this. any tips on how to make it stay in the headliner? + where did you get the paint from?
