Coil pack discoloration
Old Feb 18, 2010 | 02:42 AM
Koi's Avatar
Koi
Was checking my spark plugs today and saw that my #3 coil pack was significantly darker in color (the red bit of it) than the other three. The spark plug itself was in identical condition as the rest, it looked fine.
Is this normal? Something wrong with the coil perhaps? Anyone have any idea?
Old Feb 21, 2010 | 02:30 PM
justdriving's Avatar
I recently replaced all my coil packs after having alot of "stutter" issues. The #2 was replaced by a dealership when i originally had a problem away from home. I replaced the other 3 myself and the #3 was also miscolored (much like in your picture). Since replacing the rest of the coil packs the stuttering has gone away. I do have 123,000 miles on the OD. Are you having engine stuttering- at speed -50-65mph or at idle? You may want to start with the # 3.
Old Feb 21, 2010 | 04:00 PM
Koi's Avatar
Koi
Car is at 37,000 and haven't noticed any stuttering. The coil pack was normal color at 29,000 when I last changed my spark plugs. Everything seems fine for now... but if there's any stuttering or misfires down the road this seems like the place to start.
Old Feb 24, 2010 | 01:28 AM
Koi's Avatar
Koi
Okay now I am finding there is some stuttering while the car isn't yet warmed up. From a cold start up to around 175-180 degrees F, the idle rpms will drop from 850 to 700-750 then jump back up to 850 in a split second. This happens every 5-10 seconds until the car is warmed up, at which point it stops. I'll be switching out the discolored coil pack and see if this issue goes away.
Hondarian
Jan 15, 2017 09:57 PM
codenamezero
Mar 2, 2014 04:00 PM
Harriswt
Mar 19, 2013 01:56 PM
RCpilotjr
Jun 13, 2012 09:19 PM
jaymiepaige
Feb 25, 2007 03:53 PM
