Would Enkei PKR rims fit the fit?
Old Mar 23, 2010 | 05:01 PM
PA-Fit's Avatar
i have the base model fit and am looking at getting a used set of 15" Enkei PKR's. They already have P195/60/r15's on them. Would these fit onto our fits without any problems? rubbing issues?
according to 1010tires.com. The 38mm is a too low offset for a 15x6.5 wheel. (not really sure what this means)
I'm not a tech guy, i just want some nice rims that won't rub and that i will be able to take off in the winter to put the stock 14's back on.
any info will be helpful...thx.
Old Mar 23, 2010 | 05:16 PM
runbikerun's Avatar
From the reading I have done you need to ideally shoot for around a 45 offset to fit the GE. I did however purchase a set of tirerack wheels for my GE 15 by 7 in a 42 offset for my winter tires with no rubbing issues. These have Blizzak 195/60/15s. I don't know if Blizzaks run wide or narrow in comparison to other tires. (Please no thread highjacking with snow tire debates, thanks)
I hope that helps.
Old Mar 23, 2010 | 06:03 PM
PA-Fit's Avatar
thx. i'm thinking it should work. all the 15x6.5 wheels on tirerack typically have a 40mm offset.
Can i just use a 2mm or a 5/16" spacer?
Old Mar 23, 2010 | 10:50 PM
TheOrangeRevolution's Avatar
I hope that helps.
You bought wider rims/tires for winter than stock? Isn't that that opposite of what you want?
Old Mar 23, 2010 | 10:53 PM
Btrthnezr3's Avatar
That would actually throw the offset back to 38 thus making it more likely to rub...I do believe.
Old Mar 23, 2010 | 11:55 PM
Hootie's Avatar
Offset is the distance between the centerline of the wheel and the plane of the hub-mounting surface of the wheel.
Now first and for most, what chassis or year is your Fit? I'm assuming a GD because you mentioned 14 inch stockers. For sure, a 195/60R15 tire on a 15 x 6.5 rim with a +38mm offset will rub on all four corners due to the larger sidewall at stock ride height. If you had a 195/55R15 on a rim of the same dimensions with a +38mm offset, you may not rub at stock height; however, if a 195/55R15 tire was mounted on the a 15 x 6.5 rim with a +40mm offset, you will not rub at stock ride height at all.
Yes, adding spacers would lower the offset and increase the likely hood of rubbing.
Old Mar 24, 2010 | 09:36 AM
PA-Fit's Avatar
Yes, i have a GD (2008)...thx for the info. guess i'll keep looking around.
Old Mar 24, 2010 | 06:13 PM
KiD SuNNi's Avatar
hey guys i was just wondering if 17x 7 1/2 offet +42 with tires 215/45/17 fit my GE base fit? I'm not lowered yet but gonna get springs this week. please help!!!
Old Mar 26, 2010 | 10:25 AM
PA-Fit's Avatar
Just a question...is there a way to increase your offset? from the 38mm to 40mm???
Old Mar 26, 2010 | 11:51 AM
Hootie's Avatar
Sure by shaving the hub of the rim some; but, I wouldn't recommend doing that for safety reasons.
Old Mar 26, 2010 | 01:57 PM
PA-Fit's Avatar
maybe the best option for me is to get 195/50/r15's to go with the enkei pdr's since they have a 38mm offset.
you think that would work?
crimsona
Nov 11, 2010 09:56 PM
Fab
17
Sep 20, 2010 01:19 AM
sirfit08
Sep 5, 2008 07:32 PM
southwilrise87
Sep 5, 2007 09:04 PM
