205/50/ 15*6.5 +38 rub?
Old Apr 18, 2010 | 11:39 AM
07_g_fit's Avatar
I looked at a bunch of posts and doesn't seem like I can find one with this exact tire. It's going on a GD3
konig feather 15x6.5 +38
with a 205/50/15 tire
I've seen that 195/55/15's work, so would these also work without rubbing? Thank you.
Old Apr 18, 2010 | 12:05 PM
Texas Coyote's Avatar
I am thinking you would have some rubbing... The tire would be protruding 22mm further out than the stock Sport wheel and tire.. You can squeeze the fender inner lining to get some additional clearance and the rubbing wouldn't be constant but on bumps and full lock turns there will be a little rubbing... Possibly more so if your car is lowered but you might be able to live with it.
Old Apr 18, 2010 | 12:53 PM
Hootie's Avatar
I'm running 205/55R15s on a 15x6.5 +40 Konig Quiz and at stock height. My tires are taller than yours and my offset is slightly higher, but I can assure you that in the front you will not rub the inside of the tire when turning. As for the outside of the tire, I don't think you will rub because another member here was running a 215/40/R17 tire on a 17x8 +32 rim with GF210s and he said that he didn't rub in the front. If you do rub in the front, just tuck the fender liners.
Now for the rear, I rub a mm or two shy of the screw that is attaching the bumper to the body of the Fit. Again, I have taller tires because of the sidewall; so, if you are at stock height you might rub on that screw on a hard bump or with passengers/cargo in the rear of the car. If you are lowered, then you will rub on a bump or with passengers/cargo in the rear.
Old Apr 18, 2010 | 12:58 PM
DreaMv's Avatar
im 15x6.5 +38 on a 195/55/15 tire and i still rub on a fast turn or a hole in the street.
Old Apr 18, 2010 | 01:02 PM
Hootie's Avatar
Front or rear, what ride height, and are your fender liners tucked?
Old Apr 18, 2010 | 01:08 PM
DreaMv's Avatar
front rubs and i have no fender mods at all. on springs
Old Apr 18, 2010 | 04:35 PM
MNfit's Avatar
FYI Hootie +40 is a higher offset then +38
Old Apr 18, 2010 | 05:52 PM
Hootie's Avatar
I know; the higher the number the more sunk in the rim is, the lower the number the more it sticks out. (In the case of positive offsets)
That is why I said in the first paragraph the inside of the tire will not rub as well as mentioning another member's set up who had a wider tire and wheel combo to clear any confusion about the outside tire rubbing. In the second paragraph, I said that running the 205s on a +38 rim may hit the screw because it is 2 mm (0.07874 inches) closer to the screw (2 mm outward, away from the car) than on my set up.
Edit: I see what you're talking about now. Proof reading FTL.
Old Apr 18, 2010 | 07:25 PM
MNfit's Avatar
I had 195/50/15 with a +38 and lowered on progress springs with out any rubbing issues, if I remember right
Old Apr 19, 2010 | 10:45 AM
07_g_fit's Avatar
Wow thanks for all your replies.
I'll probbably pass on this as I do have some T1R lowering springs coming in the mail. When-ever I have to buy new tires, I like to check out the classifieds for some good deals on wheels.
FITProject
May 10, 2011 07:02 PM
fitster
Jul 6, 2010 10:30 PM
roflmayorga
Jun 4, 2010 04:59 PM
Skytraveler
Jan 31, 2009 04:08 PM
08FitSport
Jul 20, 2008 08:41 PM
