Can it be? A turboed car slower than the Fit?
Old Apr 19, 2010 | 04:50 PM
Committobefit08's Avatar
According to Motor Trend the new Chevy Cruze has done it.
Engines 1.8L/138-hp (est)/125-lb-ft (est) DOHC 16-valve I-4; 1.4L/138-hp (est)/148-lb-ft (est) turbocharged DOHC 16-valve I-4
Transmissions
6-speed manual, 6-speed automatic
Curb weight
2800-3150 lb (est)
0-60 mph 8.5-9.4 sec (MT est)
Read more:
2011 Chevrolet Cruze interior and initial specs - Motor Trend
Old Apr 19, 2010 | 06:37 PM
JJIN's Avatar
must be bad power to weight ratio. also it might have mismatched gearing to the engine output.
our fits are slow but they are no slugs, chevy should up their game some to beat out ford'd fiesta.
Old Apr 19, 2010 | 07:05 PM
YA2_user_GD3's Avatar
the weight seems a lot more, if i recall the fits only around 2500
Old Apr 19, 2010 | 07:32 PM
Goobers's Avatar
Well, firstly... those numbers are just estimates so far.
Secondly, yes, the Cruze is at least 300-650 lb heavier.
The estimate of "8.5-9.4 sec (MT est)" doesn't indicate if that's for BOTH Turbo and non-turbo... or just one of them (in that case, which?).
If you want to make assumptions... then, 8.5 (the lower of the estimate range) might be reasonable, considering the added weight. Now, if you then reduce the weight of the Cruze by 300-650 lbs (to more closely match the Fit), it would probably then beat the Fit.
Of course, it's entirely possible that the Turboed version is getting the slower number of 9.4 due to weight (650 lb end). And who knows at that point if you can get enough weight savings to beat the Fit.
We'll have to wait until MotorTrend puts non-estimates up.
Old Apr 22, 2010 | 06:55 PM
kennef's Avatar
factory turbo car means so much more potential at much more reasonable prices.
Old Apr 22, 2010 | 07:43 PM
huisj's Avatar
The Cruze supposedly weighs around 3300 lbs from what I read the other day. And the interior is so big that the EPA will classify is as a midsize based on passenger volume. Almost sounds more like it's around the class of the old small midsize sedans that were more popular in the 90s like the Contour, Mazda 626, Corsica (puke), old Malibu (late 90s), early Altima, etc.
So in other words, I'm not sure what the point being make by the OP is supposed to be.
secondspassed
Sep 12, 2019 06:00 AM
Tork
Car Shows, Events, and Racing
69
Oct 19, 2014 08:44 PM
DiamondStarMonsters
Mar 20, 2012 10:21 PM
Kwonye
Jul 15, 2010 05:51 PM
Sam Misled
21
Oct 2, 2008 04:52 PM
