Pressure Testing (Long Post)
Old May 19, 2010 | 04:09 PM
apexanimal's Avatar
i thought i would share some of what i learned today in hopes that it might help someone on here... and the fit is the other half of my car family...
keep in mind this was all done on a ptgt, so some things are different, while some things will most certainly apply...
i plan on doing some pressure testing on the fit itself, specifically in an effort to find the best place to draw air in from for the intake system...
here you go:
this is long... if you don't want to read it, don't ask for a cliff's notes version, because there is actual data that is important...
so following autospeed's lead... i ordered a dwyer magnehelic guage that reads up to 3" of water... (if you don't know what i'm talking about go google it)... this is more than adequate for aerodynamic testing, but not nearly enough to test intake systems...
i wanted to test the following:
could vents be placed in the hood to help cool the engine and make the rad more efficient?
could a hood scoop be mounted to draw air into an intake?
what does taking off the weather stripping in the rear of the engine bay do?
is the fog light area, where the turbo's draw their air from, a good place to do so?
would adding vents, or a diffuser, to the rear bumper help the aero?
Hood
if you look on the underside of the hood, there are three areas that aren't braced and are just the outer shell... these are the areas we tested since these would be the easiest to cut... i tested the middle section at the beginning of the area, the middle, and the rear... the side section i tested the same way...
we tested the underside at each of these locations, and the outside in order to see what the pressure differential was... here's what we found
Middle Front: +0.5" under; -0.7" outer
Middle Middle: +0.5" under; -0.5" outer
Middle Rear: +0.6" under; +0.5" outer
Side Front: +0.5" under; -1.5 outer
Side Middle: +0.6" under; -1.0 outer
Side Rear: +0.7" under; -0.6 outer
What it means: the areas which are the best to draw air out of the engine bay, to vent hot air and increase flow through the rad and maybe the fmic are found in the front 2/3's of each section...
simple louvers would work (tai did something right ) or a larger single vent...
in order to create a hood scoop that would actually do something, you'd either need to place it several inches off the hood to avoid the laminar flow, or in the middle close to the windshield...
mike's cowl hood works well because it draws in the positive pressure from the cowl area, and deposits it in the middle middle section where there is slightly less pressure... we've verified this using wool tufts
Rear Hood Weatherstrip Removal
moment of truth:
at the rear middle of the engine bay we saw a +0.6" of water, and in the cowl area under the hood we saw a +0.8" of water... therefore (no surprise to some):
opening up the weather stripping at the rear of the hood draws air into the engine bay at speed, and allows simple heat venting at rest...
this most likely helps to cool the rear of the engine bay where the turbo and manifold are... but, i'm unsure as to how this affects the radiator flow... i'm inclined to think that it cuts down on rad flow because of the slight bit of pressure increase in the engine bay...
Radiator/FMIC Flow
in front of the rad: +1.4"
directly behind rad: +0.7"
in front of the fmic: +1.6"
directly behind the lower rad: +0.6"
these measurements were done with all stock weather stripping intact...
we measured the pressure at the rear of the fmic by going behind the rad... reason being: the fmic sits so close to the rad, that there is very little venting that goes on between...
this was also tested using joe's/bell's stage 2 4.5" cored fmic... take that into account... also, this was done with a lower grille cutout which i'm sure increased the amount of pressure that is seen at the fmic... i'd be more than happy to test this assertion on a ptgt that still has it's lower grille intact...
i am also missing the middle portion of the chin spoiler that is on the ptgt air dam... this helps to create a low pressure area just behind it in an effort to draw more air out from behind the lower rad and front engine bay area... i'm fairlly sure that if i was to add one that was approx 1" tall, i would be able to see some additional flow through the fmic due to a lower pressure area behind the lower rad/front engine bay...
Air Intake
the fresh air that the stock ptgt airboxes draw from is the driver's side foglight... this has never made sense to me as i didn't really believe that it saw much airflow or pressure sunk so deep into the airdam... this is also the same area in which the "brake ducts" are...
the pressure on the front of the fog lights was measured at +1.8"... the highest pressure area we tested (it might be higher at the very front of the bumper but we didn't test there)... needless to say i was impressed...
this means that the brakes are actively cooled by the air flow (the wheel well area was measured at approx +0.3") and it's a very good place to draw air in from... the trick is how to do that without compromising the brake ducts, or removing the fog lights... (i have an idea but that's to come later)...
so if you don't have fog lights, it's a no brainer... find the largest diameter flexible tubing that you can find, and run it between the fog light opening, and attach that thing directly to your airbox, and profit! better throttle response and more efficient engine breathing...
Rear Bumper Area
this was by far the most surprising for me... i had expectations, and they were not met...
pressure at the rear of the bumper: +0.5
pressure at the front of the bumper: +0.5
i had expected a low pressure area to be found at the rear of the car created by the wake of the car, and a high pressure area to be found under the car at the front of the rear bumper created by a paracute effect... nope.
i had an idea before this testing that by cutting two openings in the sides of where the license plate is, i would be able to increase flow, and cut down on drag a bit... nope.
is a diffuser a bad idea then? not necessarily... a diffuser smooths the air flow, and works with an undertray and front splitter to better create a low pressure zone under the car and smoothly transition it to a higher pressure flow behind the car... this is still a good idea, but it needs to be done with a full undertray to reap the most benefits...
Conclusion
improvements can be made... but they need to be done intellegently to benefit the most...
so go and do likewise...
Old Jun 2, 2010 | 03:07 PM
apexanimal's Avatar
popular thread
i did some direct testing on the fit today... here's what i found:
i did testing for the best place to route a snorkel to, in order to draw in higher pressure air... using this high pressure airflow will help to make up for imperfections in any intake system, and could introduce positive pressure on the intake side of the tb...
i did all the testing at 45mph...
i tested from the three most likely areas to route a snorkel to the intake area:
1. the upper sport grille area on the driver's side
2. the lower grille area on the driver's side where it diverts air to behind the fog light
3. the driver's side cowl where the rouge scoop is placed
here are the numbers:
1. 1.2 - 1.3" of water
2. 0.8" of water
3. 0.7" of water (this could be slightly higher with a scoop in that it also catches air that is off the surface)
what this means:
the ideal place to draw air in for an intake, without drilling holes in your bumper or cutting your hood up, is from the upper grille area...
i'm going to be experimenting with some different ideas with trying to get this to work... i'll see if it'll pan out...
Old Jun 9, 2010 | 02:45 AM
jazzista's Avatar
Great info! Due to my poor english I often miss something. Do you mean the black slotted plastic under the windscreen?
Thanks a lot for sharing!
Old Jun 9, 2010 | 10:31 AM
apexanimal's Avatar
not sure which section you're asking about, but the ideal place to draw in air is from the upper grille where the large honda "H" is...
Old Jun 9, 2010 | 11:26 AM
apexanimal's Avatar
sigh...
drawing in air from a higher pressure area will help to make the intake system much more effecient... throttle response will be better, car will pull better, etc...
it's not about "ramming air", or cold air, although these will happen to a degree...
check out autospeed.com for more good info on this stuff...
Old Jun 9, 2010 | 12:53 PM
apexanimal's Avatar
thanks for your post
Old Jun 9, 2010 | 05:54 PM
apexanimal's Avatar
now seriously... gtfo of the thread unless you're going to contribute...
Old Jun 9, 2010 | 09:09 PM
apexanimal's Avatar
Originally Posted by Black3sr
This is a thread? More like you rambling about some super duper intake to add huge response to the Fit.
I suspect Honda has already determined where the best place is.
Bye
do much engineering do you?
sorry if actual data is rambling to you... usually you shouldn't fault the op if you can't understand what is going on...
and i don't believe (i don't even have to guess - just take a look at the previous posts) i ever said that it was going to give you 10 hp, and the ability to keep up with f/i cars... but it surely improve the efficiency... unlike those lovely chrome pillar posts and blue drums - top notch tiger
i posted this up because this is stuff i was looking into with other forums, and i figured i'd post it here... believe me that i'm not going to loose sleep over you not understanding what's going on here, or anyone posting... notice i even made fun of the thread long before you got here...
thanks again for posting pumpkin... been a pleasure.
Old Jun 9, 2010 | 09:23 PM
Daemione's Avatar
apex, thanks for the post. It's been lurking on the edge of my awareness for a while now, I've been waiting for a rainy day to go over it all.
black, quit being a dink.
Old Jun 10, 2010 | 02:51 AM
jazzista's Avatar
Talking
Thank you for your patience, I realized just after googling for "sport grille". But I seem to remember it wasn't much room to route a snorkel. I'll check again and - to be clear - I rate posts like yours much interesting and very informative, aimed to share knowledge and experiences. Definitely exactly what a forum is supposed to be!
Thank you again Scott.
Old Jun 10, 2010 | 10:30 AM
apexanimal's Avatar
no worries...
thanks mods for cleaning this thread up...
what i'm thinking is routing a forward facing duct just behind the grille, running it 90* up and cutting a hole in the plastic bit, then routing it to the inlet of the airbox... that's at least my thought right now... i have to do the clutch line and readjust the valves before i get to this... i hope relatively soon...
dae - let me know if you have any ideas...
Old Jun 10, 2010 | 11:51 AM
Black3sr's Avatar
No thanks to Mod. I removed them. I re-considered and found the testing you are doing will amount to nothing and was a waste of my time posting
Oh the blue drums and stainless not chrome posts added another 5 hp without blowing smoke out my azz about some intake. May your snorkel suck up a puddle.
bye
Old Jun 10, 2010 | 12:02 PM
apexanimal's Avatar
bye
quoted for evidence later...
Old Jun 18, 2010 | 03:08 PM
chrisakasparky's Avatar
bump for someone who has triple digit intelligence.
Old Jun 18, 2010 | 05:52 PM
apexanimal's Avatar
winter park huh? i used to live in clermont... howdy...
Old Jun 22, 2010 | 04:33 AM
Lyon[Nightroad]'s Avatar
Pull out a fog light and measure that? I'd be interested.
Old Jun 22, 2010 | 10:10 AM
apexanimal's Avatar
i'll try that when i get a chance... this would be the easiest solution in terms of ducting air... i just like fog lights too much to take them out
it may be a little while but i'll post up when i've got something...
Old Aug 16, 2010 | 08:12 AM
HOLY FIT!!'s Avatar
haha i am simply astounded at the fact that someone on here can attack another member who is positively contributing to this forum. just plain sad. good data man, way to think outside the box!
Old Aug 18, 2010 | 08:21 PM
apexanimal's Avatar
^thanks...
i haven't forgotten about you Lyon... i'll get to it once the fit gets back from the shop...
i'm still fairly set on drawing air in from the upper grille area... i just don't want the duct to get snow packed in and have a host of issues on my hands... but routing the duct work up there will take some doing...
Old Sep 17, 2010 | 12:21 AM
Blue-Civic-Hybrid's Avatar
Excellent!
Apex , excellent post and thank you for the information and data. I have been thinking about a rear lower panel (have the BeatRush and love it) for the rear of the Fit and after reading your results, I am a little hesitant to start cutting up some big sheets of aluminum!
I am looking forward to your "ducting" from the upper grill area, hopefully some measurable gains will come from it.
