15" tire help plz
Old Jun 3, 2010 | 05:54 PM
roflmayorga's Avatar
Exclamation 15" tire help plz
wondering whats the fattest biggest widest tire i can put on 15x6.5 4x100 40mm os 73.1mm hb konig heliums with stock suspension
Old Jun 3, 2010 | 06:35 PM
Hootie's Avatar
205/50R15s may work so long as you don't hit a very hard bump, a deep dip, or have a heavy load on. If that bothers you, you would be better off getting some 195/55R15s.
I'm running 205/55R15s with stock springs and I rub at all 4 corners due to the tire being taller and wider than the 195/55R15s on hard bumps and deep dips.
For me, tucking the fender liner fixed the front rubbing and in the rear I just let it rub on the bumper's tabs, just about a centimeter shy of the screw holding the bumper up.
Old Jun 4, 2010 | 02:39 AM
xonexlifex's Avatar
ya i wuldnt go any more then a 205 50 series, i have nitto 205-50-15 on +35 wheel offset, i never rub in the front but in th back is a different story, i have to shave the back plastic bumper and rolled the fenders a little bit and put two sets of spring rubbers just so it wuldnt rub in the back wen theres people or heavy stuff in the back, if u want there to be less rubbing go with the 195 but if u want a little wider than stock and may have to do some stuff to get it to not rub than go with the 205s. but if u do go with the 205s then get the spring rubbers first before doing anything bec that was the most help for me
Old Jun 4, 2010 | 07:30 AM
ill probally go with the 195/55/15 kumho ecsta asx and the heliums, thanks for the help
Old Jun 4, 2010 | 04:41 PM
grtpumpkin's Avatar
You guys must be running some goofy offsets to be rubbing on 205s with stock suspension height! I'm dropped on Skunk2s with 10mm spacers in the back on 205-50s and have never rubbed at all. This is stock wheels BTW...
Old Jun 4, 2010 | 04:59 PM
Hootie's Avatar
In one of the various wheel and tire treads for the GD, it was noted that the lowest offset that a GD with 205s could run is +42 w/ stock springs and +45 lowered.
I barely rub in the rear and seldom in the front without tucked fenders due to having a taller 205/55 (approximately 24" O.D.) opposed to the shorter 205/50 (approximately 23.2" O.D.) with my 15x6.5 ET+40.
FITProject
May 10, 2011 07:02 PM
07_g_fit
Apr 19, 2010 10:45 AM
Nick_
Oct 2, 2009 04:06 PM
08FitSport
Jul 20, 2008 08:41 PM
rabbitron
Apr 23, 2008 12:52 AM
