Help on spoiler
Old Jun 7, 2010 | 02:29 PM
bellzGD3's Avatar
Help on spoiler
Hey guys I just got my rear spoiler for my fit from a friendly fitfreak friend =).. don't really want to drill.. Ive read that people use 3m tape just wonderig how this works and what kind of
3m should I get.. Thanks for the help guys
- heymike that's again for the spoiler !
Old Jun 7, 2010 | 04:36 PM
Fit_Mike's Avatar
i just drilled better feeling for me, 3m tape wears out and i didnt want to be driving down the road and my spolier flys off. But that is just me..I dont know what tape you can use I think they have Gorilla 3m tape???
Old Jun 7, 2010 | 05:18 PM
bellzGD3's Avatar
Any tips or how to drill it? Tools beside a drill
Old Jun 7, 2010 | 06:49 PM
GD3_Wagoon's Avatar
nothing drills better than a drill
measure twice, start with a pilot hole, then commit. good luck!
Old Jun 7, 2010 | 07:40 PM
JDMchris.com's Avatar
I run THIS
I would only use the tape as a last resort or if there is no way to drill... Im assuming this is a spoon or spoon style spoiler... The 3M will hold, but it will lift on the edges after some time... but it will not fly off your car. But i would suggest drilling it... its not very hard.
Old Jun 8, 2010 | 10:32 AM
Fit_Mike's Avatar
measure twice...it wasnt that hard..Theres a right up that he did for using the double sided tabs that came with the spolier as a template..
Old Jun 8, 2010 | 01:11 PM
bellzGD3's Avatar
Hey guys thanks for all the input got done putting the spoiler last night it's hooked on nice drilled 5 holes.. There's a little slight problem the 3 studs are a little visible but barely i bought this spoiler used so it didn't cone with nuts or template jut the two bolts on each end
Old Jun 8, 2010 | 09:18 PM
MNfit's Avatar
I see you already got it on but ill throw my .02 in any ways
When I put on my spoon spoiler I used painters tape and taped up the top so I could mark it up while make measurements. I had my brother help me and we measured about a half dozen times. When we were confident we got it we used a center punch to to mark the holes, then I think used a very small bit to make a pilot hole.
Old Jun 8, 2010 | 11:36 PM
danger69's Avatar
Make sure you guys use some painters putty around the holes to keep out water from seeping in. I've seen spoiler holes that don't have the putty and the water will start rusting the hole and gets messy in the long run.
Old Jun 9, 2010 | 01:08 AM
GD3_Wagoon's Avatar
painter's putty or any type of silicone sealant will prevent water from entering and, more importantly, protect against rust.
fitfit123
14
Jul 23, 2009 01:21 PM
jvm051
Sep 14, 2008 04:29 PM
GlennD
Jun 17, 2008 03:04 AM
kevjandon
Apr 9, 2008 04:40 PM
TeamStaNceFIT07
Feb 29, 2008 09:05 PM
